I.R. in love with you!
Unread 08-01-2014, 23:05
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: Bag Motor Tips
Ball pick up at full speed.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 08-01-2014, 23:42
T^2 T^2 is offline
FRC #5499
Re: Bag Motor Tips
Use a MiniCIM in a VersaPlanetary instead. Will save your bacon at your first regional.
Unread 08-01-2014, 23:48
AdamHeard's Avatar
Lead Mentor
Re: Bag Motor Tips
I fail to see how a bag motor isn't robust enough for an intake roller. MiniCIM is more robust for sure (based on it's power/weight ratio), but that doesn't mean the bag is a bad choice.
Unread 09-01-2014, 00:30
T^2 T^2 is offline
FRC #5499
Re: Bag Motor Tips
We burnt out one on an intake-related mechanism last year. Granted, part of this was to suboptimal friction within the system, but we ultimately just needed more power. Because the motor allowances are the way they are, MiniCIMs generally carry more advantages this year.
Unread 09-01-2014, 13:50
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
Re: Bag Motor Tips
Have you checked out the dual motor input for the VexPlanetary? The BAG motor runs much cooler than a Banebot motor. We have had to fan cool the Banebot motors being used in a high torque on/off process.
A cool design would be to use one transmission to ready the catapult, shift and lower the collector arm then run the roller.
Anybody ever build a 3 speed with neutral dual motor PTO transmission?
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 09-01-2014, 14:27
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Bag Motor Tips
Roy,
Why do need a 3 speed? A 2 speed with a neutral/3 position would work for almost any first application.
R.C.
MadTown Robotics Team 1323
Unread 09-01-2014, 14:51
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
Re: Bag Motor Tips
RC,
Just thinking out loud.
Engage gear to arm the launcher,
turn gear to bring launcher arm back
at load position lock the arm with cam
shift to engage intake arm gear, two belts are driven at 15:1 to hit the sweet spot for the bag motors.
to forward roller arm, and turn the roller . The belt for the arm is on a clutch once the hard stop is reached it clutches the belt but the roller keeps rolling to intake.
Two motors + 1 transmission=cool design
PS> RC the Versa blocks are super cool. Great idea. You could extrude the design to reduce the manf. costs. All you need to do is obround slot the tubes and teams wouldn't even need to cut holes into the tube. I could have a tool made to progressive punch the slots.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
