Go to Post Thank you NASA (except for Dave, his tormenting hints make us even) - Mike Schroeder [more]
Unread 08-01-2014, 15:13
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Re: [Ri3D] BOOM DONE. We're not done...
I am still in awe as to how you guys pulled this off. This robot looks like it can compete with the best of them.
I really like the acquiring system and the consistent catapult. And Im baffled at the amount of electronic features this robot has built into it.
A sure winner of the Ri3D lot if you ask me.
Unread 08-01-2014, 16:47
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by pilum40 View Post
Dr. Joe:
I'm the coach for Team 3355 in Arlington, Texas. My team is frankly open mouthed about Boom Done. We did have a couple of questions please...for now...
1. When you use "green cord" in your shooter", what kind of cord do you use? Did you custom make the pulley for this cord or is it off the shelf?
2. What was the gauge of wire you used for your catapult/shooter? Did you hand form it or have it made?
3. What was the material you used for the "Toro Horns" please? We have a running bet (lunch) that it was rough sports tape or something similar. Please let us know, we're all hungry!!
Thanks in advance!
Steve Miller-Coach
The Purple Vipers
Green Cord. It is the metric size solid core urethane round belt on this page from McMaster I use a ton of the 6mm (8112K33), but the 4mm stuff is also great. Run it around the pulleys to get a free length, cut the belt 3-6% short, use a lighter to melt the end (act like you are making a golden brown marshmallow), press together the ends, hold til cool, trim the joint with a side cutter. It is a REALLY useful way to spin something at a distance.
Pulleys are laser cut acrylic 1/8th thick. We cut a ton of these with a "FIRST standard" bolt hole pattern 1/2" increments. We then can stack up plates to make pulleys. These are not just good for actual robots but especial for prototyping.
Loop Gauge of wire is 1/4" steel. We had it laying around the shop.
Toro Horns. You are not going to believe it: Schedule 80 PVC (thicker wall than Schedule 40). I heated up some 1/2" hex shaft and melted it in place so that a Versaplanetary shaft fits tight inside.
Dr. Joe
* which roughly stated is (6) #10 holes on a 1.875" bolt circle with a 1.125" center hole.
Team #88, TJ2
Unread 08-01-2014, 17:08
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Does Ri3D give an "Innovation in Control" award? If so, you nailed it.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Robotics Association at UW-Milwaukee
Website, Facebook
Unread 08-01-2014, 18:41
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Great job, I love how you all managed to innovate in such a short amount of time.
What was the final gear ratio for shooter?
Unread 08-01-2014, 19:10
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
Bravo, my new favorite RI3D team, i'd not be surprised to see this robot in the championship finals.
I really loved that bumper idea and you really innovated with the control stuff and sensors. Are you going to post the cad models and code you used? Where?
Unread 08-01-2014, 19:13
AKA: Dr. Joe
FRC #0088 (TJ2)
Working on a spec page but 15:1 is the short answer.
Team #88, TJ2
Unread 08-01-2014, 23:08
mbshark's Avatar
mbshark mbshark is offline
AKA: Myles Byrne
FRC #3932 (The Dirty Mechanics)
mbshark is an unknown quantity at this point
Will there be a vid on the youtube channel or twitter or something on robotin3days.com when you guys put up a cad? Right now each team's blog is just bios of you guys like its been for forever and the only place where you see new stuff is youtube and twitter. Also the only CAD for Ri3D that I found was team Andymark and it was on a CD post - Are there any more currently available?
Unread 09-01-2014, 00:27
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
How did you handle the Max RPM difference between the CIM and Minicim? Did you do anything or are they close enough to be interchangeable?
Unread 09-01-2014, 07:31
Shmuel Shmuel is offline
FRC #4817
Shmuel is an unknown quantity at this point
Originally Posted by Joe Johnson View Post
15:1
Is that gear ratio including the sprocket, or just the gear box?
Also thank you for what you are doing, your robot is really amazing.
Unread 09-01-2014, 16:01
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I'm completely in awe of this "3 day robot", Amazing!!
We are planning on doing a similar process with a range finder + display, though it will be with our own twist of course.
We too plan on using a couple of onboard co-processors to do this work. Arduino for display and PCDuino for vision. This will eliminate the need for any additional WiFi bandwidth.
I would love to see the Arduino code you are using and any specs you might have on the US sensor you used.
What, if any, protocol are you using to communicate between the Arduino and the cRio?
Unread 09-01-2014, 16:24
AKA: Dr. Joe
FRC #0088 (TJ2)
Working on publishing this. Stay tuned.
Joe J.
Team #88, TJ2
Unread 09-01-2014, 16:51
msaunders msaunders is offline
AKA: Mike Saunders
msaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nice
Very Nice.
What is the reduction used for the macanum's?
-= 862 =- Lightning Robotics, Canton, MI
2015 FiM Bedford District Chairman's Award
2014 FiM Bedford District Winner
2013 12th seed, Curie Division Winner with 1678 and 148
2013 Michigan State Championship Entrepreneurship Award
2013 FiM West Michigan District Winner, Engineering Inspiration Award
2013 FiM Kettering District Winner, Engineering Inspiration Award
Unread 09-01-2014, 21:16
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
What's the tooth count on the top drive sprocket??
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 10-01-2014, 00:10
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Dr. Joe
I am assuming this is in the works as well, but we are really curious on the reduction used for the Toro Horns and if you feel that was the optimum reduction or would have used something else if you had access to it?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 10-01-2014, 00:15
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
http://www.chiefdelphi.com/forums/sh...7&postcount=54
