Go to Post I wish I had two extra hands, so I could give those gearboxes four thumbs up! - Billfred [more]
Unread 09-01-2014, 10:27
Re: Pneumatics NOT Working - Help - Pictures included
Umm, you appear to have plugged your PWM cable leading to the Spike into a motor speed controller/servo output rather than the proper RELAY output.
If that one PWM cable on a Relay connection is from your Spike, then according to your code the Spike needs to be connected to Relay 1.
The proper connection pins are a couple of millimeters to the right of the Relay LED that is glowing. Those LEDs are side by side with the pins that are firing.
http://www.chiefdelphi.com/forums/at...1&d=1367246283
