Go to Post Time flies when you're freaking out. - Koko Ed [more]
Unread 09-01-2014, 07:50
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Vacuum Pickup
Here's a quick test we did using a cut-down bucket left over from our 2013 Frisbee hopper: http://youtu.be/tPNvIXTAd4s
Obviously we couldn't use a 110VAC shop vac, but we could connect a legal motor to the blower.
Unread 09-01-2014, 08:12
yash101 yash101 is offline
AKA: null
Talking Re: Vacuum Pickup
That seems possible. Then, you could have a kicker to kick the ball away from the robot.
If you do that, don't forget to place a shoe on the armature, just for the sake of LOLs.
You might want to try it out with a BAG. They will get up to 14,000RPM, so you'd need to see if that'd work, otherwise, 550s, 775s, AMs, etc. Just don't try a window motor .
For the kicker, you'd need to relieve the pressure as soon as kicker is about to hit it, to prevent having your vacuum following the ball into the goal, breaking it and getting your robot disabled.
Also, are you going to use the vacuum cleaner or are you going to build your own contraption? I'd like to see how it goes
Unread 09-01-2014, 09:42
dricks's Avatar
dricks dricks is offline
dricks
AKA: David Ricks
FRC #0704 (SGP Robotics)
dricks has a spectacular aura aboutdricks has a spectacular aura aboutdricks has a spectacular aura about
Thumbs up Re: Vacuum Pickup
We used a vacuum in 2010 and it worked well. we cut the guts out of a shop vac like the one in the video and replaced the motor that drove the fan with a Fisher Price motor. It worked well.
David Ricks
Mentor,Team704
South Grand Prairie High School Robotics
2012 Woodie Flowers Finalist
Unread 09-01-2014, 11:10
AKA: Kevin Thorp
Re: Vacuum Pickup
Yeah, having our robot kick itself to death would be entertaining for the spectators, but won't help us win any matches.
A kicker might work. Or swing the ball up & drop it in a catapult.
Unread 09-01-2014, 11:31
Dr.Bot
Posts: n/a
Re: Vacuum Pickup
Just for ha has I ordered the 'snowblower motor' that was on Andymark FIRST Choice. (Was practically the only thing left to order.) Don' know if we'll use it, but wanted to see if it could be used for ball pick-up or perhaps autonomous defense
Unread 09-01-2014, 11:36
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Vacuum Pickup
How far is the effective range on this? I'd like to see a prototype with a miniCIM or something to actually evaluate the effectiveness. Looks way too good to be true.
All opinions are my own.
Unread 09-01-2014, 12:03
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Vacuum Pickup
The minicim would need to be geared up (increase rpm) to really be effective. Plenty of other motors could be run direct drive with this.
Mentor 2415
Unread 09-01-2014, 12:04
AKA: Kevin Thorp
Re: Vacuum Pickup
There really isn't a "range". We have to make contact with the ball to get a seal. Alignment will be a challenge (as with any floor pick-up device). Perhaps v-shaped guides on the front of the bot?
A proper vacuum cup would probably be more forgiving to misalignment, but we had a lot of butchered-up buckets lying around the shop.
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Vacuum Pickup
I've got a shop vac like that, 2.5hp IIRC. That's about 1800watts of power. For reference, a CIM peaks around 350W and generally all other motors are less.
You might have a rough time given power limitations of FIRST-legal motors and the battery. Prototype, prototype, prototype... and consider contingency plans.
Unread 09-01-2014, 12:25
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Vacuum Pickup
Pay no attention to the power ratings of shop vacs, they are sales hype. That vac does not produce 2 1/2 HP. They play with inrush current and/or stall current to get the "peak horsepower" rating.
Former Mentor Team 1771
Former mentor Team 4509
Unread 09-01-2014, 12:26
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
Re: Vacuum Pickup
Dont go by what the HP rating is on the vac the manufactures play games with those numbers. Shop vacs dont draw 15 amps. I am looking at ours thats rated for 2.5 HP peak and it draws slightly less than 8 and is rated at 9 amps. Still not close to 350w.
Unread 09-01-2014, 12:30
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Vacuum Pickup
Most multimeters should be able to measure the average current draw.
Unread 09-01-2014, 14:25
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: Vacuum Pickup
Good info, thanks.
Unread 09-01-2014, 15:25
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
I like two Championships, AMA!
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
Re: Vacuum Pickup
We made a suction system for the 2008 game, FRC1771 did also.
You can see a modified version used in our quick video from this year:http://www.youtube.com/watch?v=3FyQQt_3u0Y.
This is a banebots 550 running a shop vac impeller. The seal is not ideal, as we just ripped the weather stripping previously used at the edge to form a seal around a smaller circle in the cone. The cone is also not shaped to this size ball.
WPI District 2016 Volunteer Coordinator.
2016 Referee: NE Granite State, NE UMASS Dartmouth, NE Rhode Island, NE Boston, NEDCMP
Unread 09-01-2014, 15:27
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Vacuum Pickup
Careful. Most multimeters have an internal fuse and are very limited in the amount of current they can measure. You will probably need an ammeter if you're using a 12V motor.
We tried to use a single fisher price for vacuum since the centrifugal fan that came from our 12V shop vac was rated at 16,000 rpm. However, the fan was enough load that the constant motion destroyed the FP. I remember another team that geared up cims and used 2 to create enough suction to hold the soccer ball.
I can't remember which team it was, but they did post the pictures here on Delphi.
Here's a part of the thread where they discuss the model number:
http://www.chiefdelphi.com/forums/sh...cim+impell er
