Go to Post A VERY credible statement ... coming from a 400-pound Pooh Bear - Rich Kressly [more]
Unread 09-01-2014, 00:16
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
how to speed the extension of pneumatic cylinders
any year throwing or shooting is involved i see this asked. the simplest and easiest way to do this is to use more cylinders, if its going to slow add more cylinders while decreasing cylinder size to keep the force the same. your limited by the size of the input hardware not the number of them. 4 1/2 inch cylinders will extend much faster then 1 larger cylinder. the rules prohibit routing multiple valves to 1 cylinder so just add more cylinders. each cylinder has its own valve the only downside is it weighs more then the single cylinder solution
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 09-01-2014, 00:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: how to speed the extension of pneumatic cylinders
You are still limited by one regulator....
Unread 09-01-2014, 00:51
cmwilson13's Avatar
but you can put a reservoir after the regulator if you need it
Unread 09-01-2014, 09:43
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
You are also limited to the CV restrictions from the festo valves because they dont you the the max flow rate since, even though the rule has changed on the CV limit the solenoid hasnt.
Unread 09-01-2014, 12:38
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
I have no idea what this statement means...
This year, there is no CV limit on valves, the only limit is the port size, max 1/8" NPT. There is no requirement to use Festo or any other manufacturer.
Former Mentor Team 1771
Former mentor Team 4509
Unread 09-01-2014, 13:13
velcro velcro is offline
FRC #0177
velcro is an unknown quantity at this point
The basic limitation is the airflow from a 60 psi storage tank to the cylinder through a length of .16" ID tubing and a solenoid valve (7.8 SCFM max for the Festo?) Multiple smaller cylinders will require less airflow per cylinder, but that doesn't help if all the air is coming from the same tank. Best case, each cylinder has its own valve and its own storage tank. I figured 5 cylinders (and 5 tanks) is the minimum, and that starts getting awkward.
