Go to Post it's much easier to build safety in to a system than to add it on a Thursday at a regional. - dtengineering [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 09-01-2014, 13:15
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Pneumatic Ball Puncher
Okay so I am apart of a rookie team this year, we are team 5107 The Neurotoxoins. We have the idea of using a pneumatic piston to literally punch the ball and propel it. The only issue is none of us have worked with pneumatic before. What we were wondering is if the piston would extend fast enough and with enough force to propel the ball. Thoughts? Ideas?
Thank you,
Brenden Geary
Unread 09-01-2014, 13:19
T^2 T^2 is offline
FRC #5499
Re: Pneumatic Ball Puncher
No.
Unread 09-01-2014, 13:26
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
The problem most teams are running into (you can find their posts with a quick search) is that the solenoids used to control the pneumatic cylinders do not allow the air to flow through them fast enough. You'll get the cylinder to move, but it won't be the punching action you're thinking of.
You could try using the cylinder to move a lever to increase the speed of the ball.
Personally, i would recommend using surgical tubing to power your shooter. You got some in your kit and it's easy to find online.
Unread 09-01-2014, 13:28
Racer26 Racer26 is offline
Originally Posted by T^2 View Post
No.
Well, its not quite that simple.
Generally speaking, no, a pneumatic piston that is otherwise FIRST-legal will not be able to impart enough energy to the ball quickly enough to "punch" it to a sufficient height to clear the TRUSS or the HIGH GOAL.
There ARE ways you can build a pneumatically powered firing mechanism that WILL do the job. Prototype your ideas and see what works and what doesn't.
Unread 09-01-2014, 13:29
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
First of all welcome to FIRST and Chief Delphi!
There are many thread on this subject started already. I would suggest that you do a search and join in on those conversations.
Good luck.
czeke czeke is offline
Tool and Die maker/Tool Designer
AKA: Carl Zechel
FRC #1091 (Oriole Assault)
czeke has a spectacular aura aboutczeke has a spectacular aura about
Agreed, from our testing, punching, using surgical tubing , say like 8 seperate rubber bands, should do the trick, especially at a 45 degree launching angle, from a predetermined sweet spot.
Unread 09-01-2014, 13:43
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
No.
I guarantee at least one robot on Einstein will use a pneumatic punch, either one large cylinder or 3-4 smaller ones.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 09-01-2014, 13:46
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
Look at the Simbotics robot from 2008. It uses what appears to be one cylinder to propel a much larger and heavier ball over the overpass.
Unread 09-01-2014, 13:50
Robotics Engineer
They used surgical tubing and a winch to shoot in 2008.
Unread 09-01-2014, 13:57
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Guarantee is a really strong word... On what basis can you be 100% certain of the types of robots that will be on Einstein?
Unread 09-01-2014, 14:17
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
I seriously doubt that. Maybe pneumatics attached to a lever arm to throw the ball, but absolutely not to punch it.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 09-01-2014, 14:41
Dr.Gusta's Avatar
Team Role: CAD
After looking at symbotics I really like their winch idea and would incorporate very well into the design and Claw we have at the moment. Are we allowed to "steal" their wench design from 2008.
Unread 09-01-2014, 14:42
AdamHeard's Avatar
Lead Mentor
I wouldn't recommend stealing their wench, but I'm sure they wouldn't mind others using that winch design.
Unread 09-01-2014, 14:56
lgphoneeric's Avatar
lgphoneeric lgphoneeric is offline
FRC #2996 (Cougars Gone Wired)
lgphoneeric will become famous soon enough
Yes, you can borrow their design. You can steal from the best and invent the rest. Look at any game and look at how many robots are based off the same design, you would be very surprised.
If you have everything under control, something's about to break.
Former FRC Driver, Alumni, Mentor
Unread 09-01-2014, 14:59
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Team 20 has prototyped pneumatic system to propel the ball. We had absolutely no luck. The system barely got the ball in the air.
