Go to Post Andy Baker is so awsome, that his presence alone at the competition caused the scoring system to crash....multiple times...at all 8 regionals. - Andy Grady [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 09-01-2014, 14:42
Xavbro's Avatar
Xavbro Xavbro is offline
AKA: Xavier Eldridge
FRC #5829 (Awtybots)
Rookie Year: 2016
Xavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to beholdXavbro is a splendid one to behold
Robot in 3 Days: Team O-RYON
Hey guys! Team O-RYON is competing in Robot in 3 Days! We have an awesome robot while using only hand tools in a University basement! I think we have accomplished something great, so please...
Check out the video of our final product: http://www.youtube.com/watch?v=uEGHOEWJxBs
Vote for us "Team O-RYON" at: http://www.robotin3days.com/votenow/ !!!
TigerBytes (FRC 4209): 2012-2013: Mentor
DiscoBots (FRC 2587): 2009: Member || 2010-2015: Mentor
Impact (FRC 2585): 2016-Present: Mentor
Awtybots (FRC 5829): 2015-Present: Mentor
Ri3D Team oRyon: 2014-Present: Programmer/Strategist
Unread 09-01-2014, 15:29
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: Robot in 3 Days: Team O-RYON
I was thoroughly impressed with both the design and final product you guys came up with. I wish you guys had had the video documentation similar to the other teams because I loved your design and would've liked to see your process. Hands down winner of Ri3D in my opinion.
Unread 09-01-2014, 16:42
Do you have a document that gives more detailed information about your robot's subsystems? I bet that would attract a lot of readers.
Unread 09-01-2014, 18:28
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Definitely my pick for the winner, I am so thankful yall did this, our team wanted to build a robot to like yours but some where on the fence till they saw the finished product. Also, what is the gear ratio on the flinger? and would there be any problem if someone hit you head on into the bottom part of the feeder? and is it top heavy at all when the feeder is up completely?
Unread 11-01-2014, 00:57
xmaams xmaams is offline
AKA: Sam Dietrich
FRC #2587 (Discobots)
xmaams will become famous soon enoughxmaams will become famous soon enough
We have a 25:1 gear ratio (two 5:1 stages) on a CIM for the flinger. We wanted to see what would happen if we use two CIMs with 20:1 for more speed and torque, but we didn't have any 4:1 planetary gearboxes.
We actually rebuilt the arm on the third day to be more rigid, but I suppose it could be damaged in a collision. We haven't tried.
The pressure to the pneumatics that raise the arm is limited by a regulator to around 30 psi or so to conserve air, but even at full pressure we don't tip when lifting the arm. Sudden acceleration with the arm raised makes us tip slightly, though.
Unread 11-01-2014, 01:56
Xavbro's Avatar
Rookie Year: 2016
Hey guys,
Sorry the documentation video and code release is taking so long. Right after we finished the build, we had to switch gears to VEXU for this weekend so we have been non stop busy. I've attached the code we used to program the robot. This includes some extra visualization tools for different controllers as well as a document describing each file in detail with links to the libraries and other things.
Feel free to ask any questions. We're working on the video and hope to get that up soon for everyone!!
Thanks for be patient with us!!
Unread 19-01-2014, 18:54
I've attached the code we used to program the robot....
Hey! I just now took a look at the drivetrain code.
I see you used Linear Interpolation Arcade ("Lerp"). I'd be interesting in hearing how that worked out for you. Thumbs up / thumbs down ?
Unread 19-01-2014, 20:56
AKA: Sam Dietrich
Our drivers all like to use tank, but I've been trying to get them to try out arcade. Personally, I like how you can tune the linear interpolation as much as you want without the clipping that other arcade drives have. It is definitely easier to predict the effect of changes in parameters.
Unfortunately, I didn't get to do any good comparisons with other arcade drives on our robot in the 2013 season because we were too unstable to turn well. Hopefully our new programmers give linear interpolation another look this year, and then I will be able to give you better feedback.
2012-2013: Discobots 2587 programming / wire tracing
2013-present: Discobots mentor
2014-present: Ri3D Team O-Ryon: programming / prototyping
Unread 28-01-2014, 20:13
msig1971 msig1971 is offline
FRC #2797
msig1971 is an unknown quantity at this point
How did you connect the CIM to the planetary gearbox? Vex doesn't support this, but I have heard of others doing it as well.
Thanks!!!
Unread 29-01-2014, 00:11
Xavbro's Avatar
Rookie Year: 2016
Thanks!!!
I believe we cut the shaft WAAAAYYYY down. I haven't looked at our robot lately due to build season picking up with the team I help mentor. I'll see if I can get some pictures up tomorrow once we get back into the high school for our meeting.
Unread 29-01-2014, 00:14
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Thanks!!!
We followed the guide that my team put together last year. It's really simple.
http://blog.spectrum3847.org/2013/01...-mounting.html
Unread 29-01-2014, 00:24
Best Available Data
FRC #1778 (Chill Out!)
Has anyone used the 100:1 Versaplanetary CIM combo in a high force application? I don't doubt that the VP is good, but without extending the keyway in the CIM it seems like you could put an awful lot of force on an awfully small key.
Unread 29-01-2014, 00:47
pavchag pavchag is offline
AKA: Paul Chaguine
FRC #5829 (AwtyBots)
pavchag has a spectacular aura aboutpavchag has a spectacular aura about
In order to connect the CIM to the Versaplanetary you need to cut the CIM shaft down to about 0.25 of an inch and use 8 screws to attach the gearbox to the CIM (eventhough the cim has 10s, the way the spacing works the 8s get pushed out and work). See this link with the cad (inventor) and here attached are 2 views of the setup!
https://www.dropbox.com/sh/95t8ia62e2dmck9/ATDGl10KRy
KEEP IN MIND: Versaplanetary were not designed for CIMs. The weak point from our testing is the key on the CIM shaft and the gear on the output shaft (has been stripped by us)
Unread 29-01-2014, 00:54
Best Available Data
Can you describe the loading with which you broke it? Did you extend the keyway or leave it the stock length?
Unread 01-02-2014, 16:17
Xavbro's Avatar
Rookie Year: 2016
We didn't break it with a load. I believe what caused it to break was the mouth we had as a "hard stop." We didn't have an actual hard stop so we just went full speed until you hit the lip and I think the repeated hits eventually broke it. We also realized that one gearbox was 25:1 and the other was ?20:1? I believe and the different torques caused it break as well. We just recently replaced the gearbox so we should have to correct ratios on both sides without any issues.
