Go to Post Suggesting change is one thing, implementing it is another. - JaneYoung [more]
Unread 09-01-2014, 15:34
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Projectile Motion
In the numerous threads, I've seen statements that shows me a lot of posters only know enough about projectile motion to be dangerous. I hope to clarify a few points, which should be applicable regardless of how you launch the game piece. Caveat: this discussion will neglect air resistance.
False: The ball will travel in a straight line before it falls.
Truth: The path of a projectile is a parabola.
Clarification: If your speed is fast enough, you can approximate the path as a straight line until the gravitational acceleration becomes significant.
False: 45 degrees is the "best" launch angle to get over the truss/in the high goal.
Truth: Maximum horizontal distance when the ball returns to its starting height is achieved when the projectile is launched at 45 degrees.
Clarification: Assuming a fixed launch speed, a steeper launch angle will cause the ball to travel higher, which means it's in the air for a longer period of time. When launching from a height above zero, an angle less than 45 degrees gives the furthest horizontal distance. (For those of you more advanced in mathematics, solve for the slope of the parabola at the point it hits the ground to be -1)
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 09-01-2014, 15:41
AdamHeard's Avatar
Lead Mentor
Re: Projectile Motion
I wouldn't make generalizations like this without also commenting that drag significantly affects the trajectory.
Unread 09-01-2014, 15:45
puneeth.meruva puneeth.meruva is offline
MIT Class of 2019
AKA: Puneeth Meruva
FRC #1501 (Team T.H.R.U.S.T)
puneeth.meruva will become famous soon enoughpuneeth.meruva will become famous soon enough
I would assume that you can't exactly ignore air resistance with such a large projectile.
Unread 09-01-2014, 15:52
MechEng83's Avatar
AKA: Mr. Cool
I don't really want to argue semantics, but a projectile is a body for which the only force acting upon it is gravity. Ergo, the drag specifically makes it NOT a projectile motion problem.
Some of the technical posts in this thread: http://www.chiefdelphi.com/forums/sh...d.php?t=124222 might be helpful to those who would like to model more of the physics. As noted in that thread, whether or not drag is significant is a judgement call and very much depends on the velocities involved.
Red Alert Robotics
Unread 09-01-2014, 16:02
Bob Steele's Avatar
AKA: Bob Steele
When launching from a height above zero, an angle less than 45 degrees gives the furthest horizontal distance. )
Not true
It gives you a greater horizonatal VELOOCITY
Horizontal Distance travelled is a combination of the horizontal velocity and the time it is applied.
The time that is applied is a function of how high the ball travels ...
You have to always consider BOTH the x and the y components of the velocity in order to determine the horizontal distance travelled.
In fact the maximum horizontal range is at 45 degrees.
In this problem (excluding air resistance) you have to solve for the height you need at the distance you want to shoot from. The solution to shooting has infinite combinations of velocity and angle and distance to the goal that are solutions.
Of course there are some velocities and angles and distances that would not provide a solution. IE launching in the opposite direction, launching straight up, Launching with a velocity of 0 feet per second...etc etc
Unread 09-01-2014, 16:31
PerpetualMotion PerpetualMotion is offline
PerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of lightPerpetualMotion is a glorious beacon of light
Originally Posted by Bob Steele View Post
Not true
45 deg gives maximum horizontal range when your starting y position and finishing y position is the same
In the case of Aerial Assist, the ball is being launched from a distance below zero, since the high goal is higher than the maximum height of a robot. Therefore, in the context of this game, the maximum distance for a given velocity will be greater than 45 degrees (assuming no air resistance)
Unread 09-01-2014, 16:36
MechEng83's Avatar
AKA: Mr. Cool
I should have clarified. The solution I gave was for the ball landing below the launch point. The point I wished to make was that the maximum distance needs the destination to be at 45 degrees, and your vertical position relative to that will affect the angle which gives maximum launch velocity. 45 degrees is solution to the special case where h(0) = h(final).
Red Alert Robotics
Unread 09-01-2014, 22:06
Parabola Equations:
http://www.chiefdelphi.com/forums/sh...d.php?t=124392
Unread 10-01-2014, 05:47
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
The best angle is 45 degrees directly at the floor. BOOM
Unread 10-01-2014, 10:12
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
False: Math like this always generates the correct design for your robot.
Truth: The math is helpful but in the end I'm just going to prototype a few designs and see which one works best.
303rd post goes out to the TEST Team, awesome job guys.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Last edited by cmrnpizzo14 : 10-01-2014 at 10:13. Reason: Realized what number post it is.
