Go to Post first post and the FRC "well what is a stick" comes in. Toothpick, does it need to be round, does a carbon fiber chain of Buckie balls count as a stick. CD posters are sooooo predictable. - Foster [more]
Unread 09-01-2014, 15:54
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Vacuum Pickup
I helped design 190's 2008 suction cup. A neat thing we learned is that current goes down significantly when the ball is captured. This is because there is less air getting in the way of the impeller blades.
Additionally, we learned that rate of removal is more important than the actual vacuum you draw. Those fabric covers are mighty porous.
Unread 09-01-2014, 16:18
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Thumbs up Re: Vacuum Pickup
You can use a model airplane prop to pull a ball in. Then just turn it off and kick the ball.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 09-01-2014, 17:31
Nathan Streeter's Avatar
Nathan Streeter Nathan Streeter is online now
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Re: Vacuum Pickup
In 2010 we also used a vacuum to hold the soccer ball. It had an excellent grip on the soccer ball (combination of suction force, area applied on ball, and "mechanical advantage" of how wide your grip on the ball is).
We used a two-stage system to pull a stronger vacuum, both stages were identical, using an impeller and impeller housing from a hand-held mini-vac with the stock motor replaced by a Fisher Price. That year we used a large, soft toilet plunger as the suction cup... I'd recommend something comparable in size to the bucket used in this video though.
Some design recommendations:
- Make sure your method of getting the cup to the ball is effective... even if the vacuum works perfectly, it will help you little if your drivers are always fumbling to acquire the ball. Iterate this, and don't underestimate it.
- Use a "suction cup" with a large diameter, but minimize the volume inside it so the vacuums don't have to evacuate as much air to get a good grip
- Find some cheap vacuums (shop vac or hand-held, probably) which you can salvage the impeller and impeller housing from. Carefully disassemble them and press your own motor on (RS550 would be my recommendation, given the high free speed, stall-less application, and excellent power-to-weight ratio).
A vacuum should be pretty low-power... Ours used two Fisher Price motors, but each drew only a few amps if I recall correctly. Don't worry much about the current draw... it won't require hundreds of watts.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 10-01-2014, 13:01
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: Vacuum Pickup
Thanks for all the great tips. We've found large diameter (=>10") vacuum cups online, but they seem to be for flat surfaces.
We have access to a 3D printer. In past years we've made molds with it & cast urethane wheel treads. I suppose we could do the same for a big vacuum cup.
Unread 20-01-2016, 14:35
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
Re: Vacuum Pickup
What does anyone think about using a vacuum for a pick-up this year in Stronghold? My team was discussing it it yesterday, so I am wondering how (or if) we should go about developing a vacuum pick-up for a low goal bot.
Unread 20-01-2016, 14:38
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Vacuum Pickup
For large game objects on a high visibility field, vacuums could be fine.
For smaller objects on a very limited visibility field, vacuums would require quite a bit of precision.
Hi!
Unread 20-01-2016, 14:42
inorbert inorbert is offline
Build Captain and Driver
FRC #5811 (BONDS)
Team Role: Driver
Rookie Year: 2016
inorbert is an unknown quantity at this point
My team tested it with low results
Unread 20-01-2016, 15:43
AKA: Kevin Thorp
Re: Vacuum Pickup
We had good results in 2014 (https://youtu.be/tPNvIXTAd4s), but decided not to use vacuum because adapting a FIRST-legal motor to a small shop vac was beyond our resources at the time. But another team won our regional with a vacuum pickup. That was Aerial Assist & the game piece was a giant yoga ball with a fabric covering.
I recommend high flow/low vacuum like a small shop vac produces, rather than low flow/high vacuum, as you would get from a venturi-type vacuum generator. Those things are small and light but require a LOT of pressurized air to work.
To prototype just cut a hole in the bottom of a plastic pail or bowl & duct-tape a vacuum hose to it. Even a cheap vacuum can generate ~60" of H20 vacuum (about 2psi). With a 6" diameter bowl: 2 psi x 3 x 3 x pi = 56 lbs lifting force! Even at 50% loss due to leakage, etc. that's still 28 lbs. You might need to vent your system to keep from collapsing the boulder.
Happy prototyping!
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 20-01-2016, 15:48
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Re: Vacuum Pickup
We've included a vacuum in our puncher prototype mechanism. So far using a shop vac we've found that the boulder lends itself well to vacuum suction for maintaining control. Also if you get the vacuum over the pinhole, it sucks all of the air out of it and makes your boulder look like a brain or a raisin. https://youtu.be/f24bk-4sZCo?t=54s So that's fun.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 20-01-2016, 15:59
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Re: Vacuum Pickup
Vaccuum repair shops are quick to give you their broken motor assemblies if you ask.
I'd agree with Taylor's assessment about the relative size of the game pieces and visibility.
It worked pretty well in 08 for 1741.
http://www.thebluealliance.com/match/2008in_qf2m1
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
