Go to Post If you promote not only the growth of your own team but of other teams at other schools you are successful. - Koko Ed [more]
Unread 09-01-2014, 10:14
adlasa's Avatar
adlasa adlasa is offline
President and Lead Programmer
AKA: Sasha
FRC #1458 (Red Ties)
adlasa has a spectacular aura aboutadlasa has a spectacular aura aboutadlasa has a spectacular aura about
CRio Flash Memory
In the WPI tutorial for vision tracking there is a warning about excessive rights to the CRio flash memory in the image tracking program.
It is in regard to writing images to the CRio memory from a camera within a While Loop
Warning: It is strongly recommended to comment out the while loop before enabling the image writes in order to preserve the cRIO flash memory. Writing the images within the while loop may result in excessive wear to the cRIO flash memory.
Is this something to be concerned about? I have a hard time believing FIRST would right their code in a dangerous way by default given that a lot of teams may be inclined to just copy and paste.
Computers run on smoke. When the smoke escapes the computers stop working.
Unread 09-01-2014, 10:17
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: CRio Flash Memory
All non-volatile flash memory has a limited number of writes before it fails. They are cautioning you that constantly using that feature, say on your robot code, can add hundreds of thousands of writes depending on how often you are writing and overwriting the pictures.
It's a bit of overkill: we're still using our first 8-slot cRIO on a regular basis and have not suffered a memory failure. However, it's sound advice. If you're not going to be using those images there's no need to keep writing them to the disk.
Unread 09-01-2014, 10:28
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Using it is okay, just be careful. It shouldn't permanently damage your cRIO, but it can definitely eat up flash memory (and slow down your connection).
Unread 09-01-2014, 14:05
Yes it is something to be concerned about. However, FIRST did not enable the image writing by default. You must uncomment the image write. They give the appropriate warning if you do uncomment the image write.
This is incorrect. You can permanently damage the flash memory in the cRIO. Like Tom and the Tutorial said, do not write more often then needed.
From the cRIO-FRC II datasheet
For information about the life span of the nonvolatile memory and about best practices for using nonvolatile memory, go to ni.com/info
and enter the Info Code SSDBP.
This leads to Understanding and Extending the Life of my Solid-State Drive, which states the following
However, solid-state drives have a limited number of write/erase cycles. This disadvantage is the primary focus of this white paper. The physical cells of SSDs wear out over time.
In practice, with the wear leveling that the cRIO performs, I would guess that each team could get at least 1 million 8k writes. Given that an image is likely larger then 8k, if you wrote an image every 20ms, the cRIO flash memory could fail in around 100 hours. But, it's easy to avoid that. Even reducing that rate to once a second makes it so that a team would never run into an issue.
Unread 09-01-2014, 16:32
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Interestingly enough, the 2014 version of WPILib/C++ writes a file to flash memory every time that the cRio boots.
Unread 09-01-2014, 18:24
Better not boot the robot more than a million times.
