09-01-2014, 16:36
Lead Mentor/Engineer
AKA: Mr. Cool
 FRC #1741 (Red Alert)
Re: Projectile Motion
Originally Posted by PerpetualMotion
45 deg gives maximum horizontal range when your starting y position and finishing y position is the same
In the case of Aerial Assist, the ball is being launched from a distance below zero, since the high goal is higher than the maximum height of a robot. Therefore, in the context of this game, the maximum distance for a given velocity will be greater than 45 degrees (assuming no air resistance)
I should have clarified. The solution I gave was for the ball landing below the launch point. The point I wished to make was that the maximum distance needs the destination to be at 45 degrees, and your vertical position relative to that will affect the angle which gives maximum launch velocity. 45 degrees is solution to the special case where h(0) = h(final).
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
