Go to Post FIRST is again mirroring real life. And in real life, when we build and design robotic and automated systems, it's safety first. Hitting a human in real life loses a lot more than 30 points. - Fred Agnir [more]
Unread 09-01-2014, 17:47
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
FRC Radio Signal Light
Is the radio signal light supposed to be connected to the sidecar or the main board? And if it's to the sidecar, what part do we need to connect it?
Unread 09-01-2014, 17:59
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: FRC Radio Signal Light
If by main board you mean the PDB, then no, it connects to the sidecar. At the bottom of the sidecar, there's a little 2 pin connection with a light beside it that says RSL. The connector looks close to the same as a female PWM, except there's only 2 holes instead of 3.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 09-01-2014, 18:03
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Check out page 10 of this document, and this schematic for more information.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-01-2014, 21:30
AKA: Akash
FRC #4684
Unhappy Re: FRC Radio Signal Light
can u send me picture please because we tried to find it but we cant find so please.
Unread 09-01-2014, 21:32
Gregor's Avatar
Page 10 of the document I linked above.
<Since 2011
Unread 09-01-2014, 21:33
CalTran's Avatar
Missouri S&T Senior
As in a picture of a digital sidecar, a picture of the RSL, a picture of the connector, or all three of these things in a system? Literally, the first link that Gregor provided shows all three of those.
Unread 10-01-2014, 14:51
mickztlin mickztlin is offline
Y_SO_CRIO
FRC #2637
Team Role: Electrical
mickztlin can only hope to improve
Its bugging me so I have to post, i believe its robot signal light not radio signal light
To the victors go the swarf!
Unread 10-01-2014, 18:30
DonRotolo's Avatar
Back to humble
FRC #0832
You are technically correct (the best kind of correct ), but I wonder if the misuse of the name caused any ambiguity or confusion.
Unread 14-01-2014, 00:56
Matt Stemple's Avatar
Matt Stemple Matt Stemple is offline
Lead Robot Inspector - Sacramento
Matt Stemple is a name known to allMatt Stemple is a name known to allMatt Stemple is a name known to allMatt Stemple is a name known to allMatt Stemple is a name known to allMatt Stemple is a name known to all
Inspector tip: Don't forget to include the wire jumper on the robot signal light as described in rule R63.
Matt Stemple
Sacramento Regional LRI, www.cafirst.org
Unread 14-01-2014, 02:42
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Are we discussing this?
Also, this is what the flashing light means:
Solid ON - Autonomous enabled
Solid ON but blinks off every 1.5 sec - Teleop enabled
Slow blink (900ms ON / 900ms OFF) - System disabled by system watchdog, user watchdog, or driver station set to disabled
Fast-slow (200ms ON / 900ms OFF) - Low battery (<12V) or no user code AND system disabled either by system watchdog, user watchdog, or Driver Station set to disabled.
Fast (200ms ON / 200ms OFF) - System error; no Driver station communication; bad cRIO image, bad team ID, extensive communication errors
Unread 17-01-2014, 08:05
Tim Lehmann4967's Avatar
Tim Lehmann4967 Tim Lehmann4967 is offline
A Sentient Being
FRC #4967 (That O.N.E Team (Our Next Engineers))
Tim Lehmann4967 will become famous soon enough
Our signal light works great, but there is a loose screw inside that rattles around, It doesn't seem to affect it poorly, but it is annoying. Any thoughts?
Unread 17-01-2014, 11:04
Beauregard Beauregard is offline
AKA: Sam
FRC #1986 (Team Titanium)
Beauregard is an unknown quantity at this point
It connects to the sidecar.
Unread 20-01-2014, 07:35
Tim,
You can pop open the RSL to look for the loose part. It is likely plastic as I don't remember any screws. If it is metal, sooner or later it will end up where you don't want it. There will be a flash of light and puff of smoke and a hole in the air where something used to be.
