Go to Post This is an engineering competition. Do some. - JVN [more]
Unread 09-01-2014, 18:34
wolfspell12 wolfspell12 is offline
FRC #3244
wolfspell12 is an unknown quantity at this point
Unhappy netbeans plugin problem
It says that the plugins are installed but we cannot find them in the plugins directory to uninstall them. The sunspot frc sdk documentation is still present which implies that they are still installed. Any clue to whats going on???
Unread 10-01-2014, 10:20
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
Re: netbeans plugin problem
The Tools / Plugins window will tell you if the FRC plugins are still installed. If they're no longer listed under the "Installed" tab, then you've successfully removed them.
However, un-installing the plugins won't delete the sunspotfrcsdk folder.
To do a clean un-install and then re-install, you should manually delete (or rename) the old sunspotfrcsdk folder.
Unread 11-01-2014, 06:55
AKA: Brad
#0190 ( Gompei and the Herd)
The uninstall / install directions are here: http://wpilib.screenstepslive.com/s/...elopment-tools
Brad Miller
Robotics Resource Center
Unread 11-01-2014, 13:38
FRC #3244
Thanks that clarifies it. we may not fix it right away its a secondary programming computer.
