Go to Post I firmly believe that it's within your power to aspire instead of lament. - Alan Anderson [more]
Unread 09-01-2014, 18:14
Joshua Sicz Joshua Sicz is offline
FRC #2403
Joshua Sicz is an unknown quantity at this point
4 wheels v. 6 Wheels
My team has done 6 wheels the past 4 years of the frc season. Last year we used 4 6'' treaded metal wheels with 2 6'' dual omni wheels. This year we are debating to only use 4 6'' treaded wheels instead of 6. We need more opinions on what are the benefits of each one are. Teams that have experience in both would help. Thanks!
Unread 09-01-2014, 18:23
Re: 4 wheels v. 6 Wheels
Originally Posted by Joshua Sicz View Post
We need more onions...
Portabella or Vidalia?
Unread 09-01-2014, 18:37
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
My team has done 6 wheels the past 4 years of the frc season. Last year we used 4 6'' treaded metal wheels with 2 6'' dual omni wheels. This year we are debating to only use 4 6'' treaded wheels instead of 6. We need more onions on what are the benefits of each one are. Teams that have experience in both would help. Thanks!
Spelling mistakes aside, a little more information would be helpful.
I assume your robot was set up something like:
t------t
o------o where t is a traction wheel and o is an omni?
t------t
What was the wheel setup?
Is that 4 6" wheels with tread instead of 6 identical wheels or instead of the 4 tread/ 2 omni configuration you had last year?
Academic Student (Forever)
Unread 09-01-2014, 18:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I'm presuming that your setup last year looked like this:
T - T - O
T - T - O
If you'd dropped the center wheel sufficiently, the omniwheel did nothing for you. If you didn't drop the center wheel, the omniwheel made it possible for your robot to turn.
If you were to instead build a drive that looked like this:
T - - - T
T - - - T
...you'll likely find that you're unable to turn effectively.
You should not make decisions based upon opinion. You should strive to understand the science that led to the prevalence of 6WD robots in FRC and extrapolate the answers to your questions from that.
In your case -- the important factors to consider are the wheelbase, the available torque at the wheels and the coefficient of friction between your wheels and the carpet. With that information, you can calculate whether or not the drive you're contemplating will work.
--Madison--
...down at the Ozdust!
Unread 09-01-2014, 18:51
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
As far as number of wheels, 6 has been a very reliable number for many teams. The difference is that 6 allows the robot to turn a lot easier than 4. Just remember to add a .125" to .187" drop on the center wheel so that only 4 wheels are on the ground at once.
Many teams have also run 8 wheels, with the center 4 wheels dropped. In both scenarios all the wheels are traction.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 09-01-2014, 19:10
t------t
t------t
Why did you assume that?
Unread 09-01-2014, 19:15
chibi_mechanic's Avatar
chibi_mechanic chibi_mechanic is offline
Future Rock Star
AKA: Emma Rose
FRC #2797 (Knight and Nerdy)
chibi_mechanic has a little shameless behaviour in the past
I'm a bit of a newbie to all this, but from what I have observed (and correct me if I'm wrong) six wheels might be the best option for this year's game. The setup provides better mobility and possibly more speed than the traditional four-wheel setup. It would also be more stable and harder to tip over. But if you're still unsure, you should try to test each setup in small scale if possible.
Unread 09-01-2014, 19:22
CalTran's Avatar
MST Rolla Senior
I have no idea why that made sense to me in my head. Changed my first post to just ask what the setup was.
Unread 09-01-2014, 19:40
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Are you driving in a wide configuration or a narrow configuration? The wheel base distance bakes a huge difference in whether you can turn well with four wheels.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 10-01-2014, 08:17
FRC #2403
We are switching from 6 identical wheels, which is what we used last year, to 4 6" wheels with tread.
Unread 10-01-2014, 08:20
FRC #2403
Sorry for me putting opinion, but yes our team makes every decision based off how it will benefit us and what we are trying to achieve. We always go for making a robot that can push other robots out of the way if we need.
And also we are used to build 6 WD robots, and that's what we know how to do pretty well for the most part.
Unread 10-01-2014, 08:22
FRC #2403
When we had all 6 wheels treaded and we did lower the center an 8th. So make the robot only on 4 wheels at one time.
Unread 10-01-2014, 08:23
FRC #2403
Haha funny. If anything Portabella.
Unread 10-01-2014, 11:18
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Do this then. The less time you spend on a drivetrain, the more time you spend on manipulators.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 10-01-2014, 11:32
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
My team has had a love affair with 4 wheels since 2012. This year is no different, and this year all 4 are direct-drive. It's so simple: no chain/belts to haggle with, high quantities of hubs to worry about or extra axles to lathe.
The wheel base (width x length) is ~28"x17". The robot would normally be 'tippy', but we have a plan for c.g. and we're going to have ~1/4" ground clearance overall for the frame. This means that the outer edges of the frame will prevent us from going all the way over in the event of a hard stop. Sure, we could put another 2 wheels in to do that for us - but why?
GitHub
