Go to Post "I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." -Woodie Flowers - Barry Bonzack [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 09-01-2014, 15:05
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
Re: Pneumatic Ball Puncher
Originally Posted by Brandon Zalinsky View Post
I guarantee at least one robot on Einstein will use a pneumatic punch, either one large cylinder or 3-4 smaller ones.
I can almost guarantee that there will not be a successful robot that uses one giant piston for this reason: You are extremely limited to the amount of air that you can get into a giant piston by tubing and fitting size, not even accounting for valve size.
That being said, I believe that it will be possible to use multiple smaller pistons to launch the ball at a decent rate.
Unread 09-01-2014, 15:12
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Look at the pneumatic rules very closely. There are deliberate specs in these rules to slow down the transfer of energy from the holding tank to the actuators (small valves, small id tubing, 60 PSI working pressure). At some point, given the mass of whatever were tossing, the physics just doesn't work out. If we were allowed to use 1" actuated ball valves and 1" tubing ...... well ...... we could be having some chunk'n fun.
Ed Sparks
MECH TECH FRC-3959
Unread 09-01-2014, 15:41
czeke czeke is offline
Tool and Die maker/Tool Designer
AKA: Carl Zechel
FRC #1091 (Oriole Assault)
czeke has a spectacular aura aboutczeke has a spectacular aura about
Keep in mind, that using a punch, similar to Team 1114 from 2008, also allows you to shoot straight ( towards an alliance partner for an assist ) &
tilting forward ( to harvest a ball from the field ). Plus, if designed with some reinforcement, could make somewhat of a mitt, for catching.
Unread 09-01-2014, 15:53
Zealii's Avatar
Zealii Zealii is offline
#QuadSquad
FRC #3494 (The Quadrangles)
Team Role: Student
Zealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond repute
This was exactly my teams idea before we prototyped. In theory, yes it would be the perfect design. After actually prototyping it, we found that the air flow through the required tubing was not high enough to actually move the ball more than a few inches off the stand. We did try many different cylinders with similar results.
2014-Queen City Regional Finalists (868 & 3506)
2015-IndianaFIRST Kokomo District Finalists (5402 & 4982)
Unread 09-01-2014, 16:33
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Not sure what cylinders you used but we tested with 2 3/4 inch cylinders of about 8 inches of throw hooked up back to back and triggered with 2 separate valves and got about 4 ft of throw.
Gonna try 3 pairs of 9/16 cylinders tonight.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 09-01-2014, 16:36
AKA: Carl Zechel
Zealii, sorry, I wasn't implying pneumatic cylinders, I was implying using stretched surgical tubing to provide the punching force.
Unread 09-01-2014, 17:00
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
What were you using for valve, tubing, etc.? Are you certain this was an FRC legal setup?
Unread 09-01-2014, 19:27
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Originally Posted by themccannman View Post
I seriously doubt that. Maybe pneumatics attached to a lever arm to throw the ball, but absolutely not to punch it.
Mark my words.
One cylinder got our team an undefeated qualifications in 2008. I'm loving your "absolutely not" certainty- our punch prototype shoots 25 feet. I repeat my guarantee- at least one team on Einstein will have a linear pneumatic punch shooter.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 09-01-2014, 19:54
bbradf44's Avatar
bbradf44 bbradf44 is offline
AKA: Brad
FRC #3344 (Robocopz)
Team Role: Driver
bbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nice
Mark my words.
Can I ask what your setup is? Like what kind of piston and flow rate? Despite warnings from others on here my team is planning on a punch shooter but we don't have enough materials to build a full working prototype then another one for the robot
2011: FRC 1922 Team Member
2012 (Build weeks 1-3): FRC 1922 Team Member
2012 (Weeks 4-Competition): FRC 3344 Mechanic and Pit Crew
2013: FRC 3344 Mechanical Lead and Head Driver
2014: FRC 3344 Team Captain and Head Driver
Record as driver: 7-11-0 and Proud of it
Unread 09-01-2014, 20:08
Are you using the cylinder end cap as the hard stop?
Unread 09-01-2014, 20:28
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
I was about to get up on my soapbox, but the topic seemed so familiar that I looked at some of my old posts and found this one from 2008.
The post atarts with this quote:
"When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong."--Arthur C. Clarke
When you act as an expert and tell people that that "it wont wok", you are not inspiring them, you are preventing them from exploring and learning.
By the way, after that post was made, the team was invited to attend championships, played in the quarterfinals there, and won the Xerox creativity award.
Please read the post and think before you stifle creativity.
Former Mentor Team 1771
Former mentor Team 4509
Unread 09-01-2014, 20:30
PANTHERPROJECT's Avatar
PANTHERPROJECT PANTHERPROJECT is offline
FRC #2064 (The Panther Project)
Team Role: Webmaster
PANTHERPROJECT will become famous soon enoughPANTHERPROJECT will become famous soon enough
Team 2064 made prototypes for a pneumatic catapult instead of the ball puncher because we had absolutely no luck with the puncher, however the catapult is making progress. We're trying out different solenoids to see which one works best and I suggest that you do the same.
Unread 09-01-2014, 21:57
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
We have tested with four 3/4" X 10" stroke cylinders with a festo solenoid valve per cylinder and an accumulator feeding each valve at 60psi and have been able to get about 7 feet straight up from the ball resting on top of the cylinders that are spaced evenly around a 4" diameter tube. We were getting 4' with three. We plan to use 6 and hold with vacuum next test. Will let you know how it works... Not a punch -- more of a put (like shot put).
Unread 09-01-2014, 22:06
We're using multiple 3/4", 12" stroke cylinders which each have their own solenoid and dedicated accumulator on the 60psi side.
[i]
Yes
Unread 09-01-2014, 22:14
Yes
May I ask, what is the part number of the cylinder?
