Go to Post Define "surgery". I think we have enough close calls with "surgery" as it is. Thank god for disable dongles. - geeknerd99 [more]
View Poll Results: What does your team use?
RoboRealm 12 14.81%
OpenCV 28 34.57%
SimpleCV 1 1.23%
None. Just we will start vision in the future 3 3.70%
Just poking in and reading this thread 20 24.69%
Other (Remember to post a reply below) 17 20.99%
Voters: 81. You may not vote on this poll
Unread 07-01-2014, 23:27
yash101 yash101 is offline
AKA: null
Vision Software comparison
OpenCV vs RoboRealm vs SimpleCV...What's the main difference? Also, what do you teams (with vision) use? I would like to know which is better prformance-wise, feature-wise and simplicity-wise. I currently have OpenCV and RoboRealm.
Unread 08-01-2014, 19:06
Re: Vision Software comparison
An option that isn't listed is the NI Vision libraries. This is what the example/tutorial in LV uses. It runs on Windows and cRIO, and has LV and C entry points for its functions.
Greg McKaskle
Unread 08-01-2014, 19:22
We use NI Vision on a LabVIEW dashboard, communicating to a java program using Network Tables. We've been much more successful with this approach then anything else we've tried (and we've been playing with vision since 2005).
I think much of the success is attributable to the great examples that NI puts together for FIRST, rather then something inherent in the library. In addition, doing vision processing on the dashboard is much easier then trying to do it on the cRIO or on a robot-based co-processor.
Unread 08-01-2014, 22:37
AKA: null
Greg McKaskle
Crap. I forgot about that. Is there a way I can edit the poll?
Unread 09-01-2014, 02:49
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
This is dawned on me:in order for a team to be competitive this year, they are required to do vision processing, and not just sending a feed to the driver station. Reason being that there is absolutely no way to tell unless you are analyzing the hot goal and/or the dynamic target. It will be interesting. A lot of teams get away with not using vision and just indexing on the field, but they can't do that this year, and computer vision has a (very) steep learning curve.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 09-01-2014, 06:24
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
Why wouldn't teams be able to just look in the camera view for illuminated goals?
Unread 09-01-2014, 09:26
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
They absolutely can, except for that pesky first 10 seconds.
Unread 09-01-2014, 10:21
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
NI vision library on the cRIO.
Unread 09-01-2014, 11:15
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
NI library for Java, on the cRIO for the last several years. Debating using OpenCV on a BeagleBone Black coprocessor arrangement this year.
Unread 09-01-2014, 13:36
AKA: Brad
#0190 ( Gompei and the Herd)
I'll throw in a plug for RoboRealm. In the past I've used NI Vision libraries on the robot and OpenCV on the driver station. Yesterday I decided to try making a program with RoboRealm running on the driver station sending data back to the robot with Network tables.
In about an hour I had a program that was detecting the hot target, and in another half hour had the data back to the robot using the built-in Network Tables implementation in RoboRealm. It's not yet doing distance or anything complicated, but it does make my little desktop robot open and close the claw based on the target being hot. I'll leave the hard parts for the students. I just wanted to see how well it worked.
I was able to test the program using the sample images that are included with the sample programs that come with all the languages. No field construction required, and didn't leave my desk.
Brad
Brad Miller
Robotics Resource Center
Unread 09-01-2014, 17:18
faust1706's Avatar
That's what I was referring to. In the past, FIRST hasn't made computer vision a requirement to be as competitive as possible, but this year they are.
Unread 09-01-2014, 20:53
AKA: null
So, I should ask why your team picked these different technologies. They all work well. I, myself, prefer OpenCV because it is so powerful. It is also well-documented, so learning it can be conquered within weeks!
Also, how do you communicate with the robot? Serial-RS232/UART, i2C, SPI, NetworkTables, Winsocks? By the way, would you guys suggest using winsocks? It seems quite easy enough to use and make a socket server using!
Unread 09-01-2014, 22:10
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Last year we used SimpleCV (python) running on a ODROID-U2 with network tables from here:
https://github.com/robotpy/pynetworktables
So we could have it all Python and it worked fine.
The year before we did OpenCV in C++ using visual studio to compile an app on the driver station that interacted with the Java network tables on the driver side. We got great distances and it ran real fast except we ran c++ on the robot side and we could not get network tables that year working. We were going to convert the robot code to Java but ran out of time. The next year network tables worked great in c++ on the robot.
We played with the code that comes with the WPLIB this year and after adjusting the HSV setting we got decent distances with that. I am still thinking we might stick with off processing. Depends on how much we have to do in Autonomous and if we want it for other uses.
Unread 10-01-2014, 11:28
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
We ran everything on a PandaBoard last year, but we will be going with an ODROID board this year, most likely. We used OpenCV and wrote our own networking libraries. The networking stuff is pretty simple in C++, so it was easy enough to write our own and it gave us more flexibility.
The kids want to use Java this year, so that will require some adjustments in the networking code, but all of that stuff is fairly universal.
Unread 23-01-2014, 12:18
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Our vision isn't very heavy on any processor except the cRio's, so we use the dashboard.
Per Audacia Ad Astra
