Go to Post This will likely fall on deaf eyes but - - JaneYoung [more]
Unread 09-01-2014, 22:23
Matt_4505 Matt_4505 is offline
FRC #4505
Matt_4505 is on a distinguished road
Precise Motor Control
Hello,
This year my team is spinning a CIM motor to move a throwing arm and I will have to keep the CIM going at a specific speed. I was wondering how the control values -1 <-> 1 (fed to a Jaguar) compare to the CIM's RPM? Is there a more efficient to go about controlling the motor? Thank you!
Unread 09-01-2014, 22:35
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Re: Precise Motor Control
You could figure out how a power value compares to an RPM through trial and error, but I would not recommend it at all.
Instead, if you have an encoder or a potentiometer around, you can use a PID control loop. There are numerous paper on CD of the code and use. The loop will use the present and past velocities of the arm (this is why you need a sensor) in comparison to the target velocity in order to compute an updated motor value. The motor value will get updated many times a second, helping your arm reach target velocity quite quickly ("quickly" depends on what motors, gearing, and mechanical arm you have). Good control loops represent programming on a higher level and can simplify quite a bit of work for your drivers, so they can focus on driving.
If you have any more questions, feel free to PM me.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Tanaythan is an unknown quantity at this point
The most efficient way of controlling a motor's RPM precisely is to have some sort of sensor control it (such as an encoder) and using a control system monitor the power sent to the Jaguar. The most common types used for robotics are PID and Bang-Bang, which have been documented well around chiefdelphi.
Tanay Nathan
Programmer
Team #3256 Warriorborgs
Unread 09-01-2014, 22:37
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
Think of the values as a percentage of the voltage of the battery, being sent to the motor. How you get around that depends on what language you use to code.
Unread 09-01-2014, 22:40
The only issue with that is, depending on the specific speed controller, the value to power graph is not linear, is different for each type of speed controller, and can be different between two controllers of the same model.
2015:
2014:
2013:
2012:
Unread 09-01-2014, 22:44
FRC #4505
Thanks! I'll look into using an encoder!
Unread 09-01-2014, 23:02
Not as common, but used successfully by some teams, is TBH. You'll find LabVIEW, C, and Java examples in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=105965
Unread 10-01-2014, 10:17
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Would TBH be more viable than PID for an application with a continuously changing setpoint (such as regulating drive wheel speed)?
Unread 10-01-2014, 10:46
Controllers are characterized by such factors as dynamic response, stability, steady-state accuracy, etc. Since PID has 3 tuning parameters and TBH has only one, PID can handle a wider range of applications.
I suspect TBH would not work as well as PID for the application you described. You might not be able to set the TBH gain high enough to get the response you want without causing instability.
Any teams out there who have used TBH successfully for drivetrain wheel speed control?
