Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 04-01-2014, 15:21
michchinn michchinn is online now
FRC #5404 (Gearaffes)
Team Role: CAD
michchinn is an unknown quantity at this point
No Source in Netbeans
I downloaded netbeans and installed the FRC plugins. However, when I create new files, I can only view history, not source code.
It is similar to the error described here https://netbeans.org/bugzilla/show_bug.cgi?id=233122, but there does not seem to be a conclusive solution.
Has anyone encountered this problem before?
Unread 05-01-2014, 13:01
AKA: Brad
#0190 ( Gompei and the Herd)
Re: No Source in Netbeans
Can you post what the version of Netbeans, Java, and the operating system and version you're running?
Just wondering if this is only happening with a particular set of versions/platforms.
Thanks
Brad
Brad Miller
Robotics Resource Center
Unread 10-01-2014, 08:17
Team Role: CAD
Thanks
Brad
I'm using Netbeans 7.4. I'm using a Dell laptop running Windows 7 Enterprise. I have a 64 bit operating system. My JRE is version 7 update 45. I can't tell what version JDK I have.
Unread 10-01-2014, 08:24
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Under the View menu select Editors->Source
Unread 10-01-2014, 08:37
Team Role: CAD
It isn't easy to take a snapshot of it, but I can't select source there, either.
I only see history in that menu.
Unread 10-01-2014, 08:43
Flywheel Police
Hmm very strange. Have you tried uninstalling and reinstalling it?
Unread 10-01-2014, 08:54
Team Role: CAD
I'm working on a school computer, so I had to obtain Netbeans using Software Center (a possible source of error). Without an administrator password, I can neither uninstall it, nor reinstall it.
