Go to Post While FIRST's goal is to inspire young people, it will be much easier to do that if we also inspire all the older people as well. - E. Wood [more]
Unread 10-01-2014, 01:00
sasha831 sasha831 is offline
Sasha
FRC #4529 (AI Robotics)
sasha831 is an unknown quantity at this point
Question 2014 Imaging Tool Not Working
Hello,
This year we got a new C-Rio, and wanted to load it up with the Java image. We have already updated all our software with the 2014 v6 update. We've set the network adapter's ip to 10.45.29.5, connected the C-Rio via Ethernet and turned on the imaging tool. Noting happens. It constantly says searching with no changes over the half hour for which we left it running. It can't find the c-rio, but nor does it tell us this like it used too.
We encountered the exact same problem when attempting to connect to our old C-Rio, which we know works.
We've also tried connecting through a working bridge.
Any Help Would be greatly appreciated,
Sasha
Theory is when you know everything but nothing works. Practice is everything works but no one knows why. On our Team, theory and practice are combined: nothing works and no one knows why!
Unread 10-01-2014, 01:17
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
Re: 2014 Imaging Tool Not Working
Did you changing your computers ipv4 address and allow your computer to connect through the Ethernet port?
Unread 10-01-2014, 04:33
cesaros cesaros is offline
César Javaroni
FRC #1382 (ETEP Team)
cesaros is an unknown quantity at this point
So what you have to do is trying to connect a crossover cable between cRIO and computers network adapter.
Let me know if anything happens.
César Luiz Javaroni
ETEP Team 1382
Unread 10-01-2014, 07:41
Do you have any other network adapters enabled?
Are you running the imaging tool as an administrator?
Does the green "connection" LED on the cRIO's ethernet port light up?
Unread 10-01-2014, 09:45
rkoripalli's Avatar
rkoripalli rkoripalli is offline
AKA: Rohan Koripalli
FRC #3735 (Klein Bots)
rkoripalli is an unknown quantity at this point
Make sure your firewall is turned off.
Unread 10-01-2014, 09:59
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
One thing to check is your alternate IP address settings; these were a nagging problem last year for me, but the symptoms were different (it would find the cRio and start imaging, but fail after the cRio was rebooted).
Where you configure your IP settings for the ethernet adapter, click the Advanced button, here there may be a 10.0.0.?? IP address, if so, remove it (this address was created by the bridge configuration utility last year, but it doesn't get removed).
Also make sure your subnet is set to 255.255.255.0 for imaging. (It should normally be 255.0.0.0 to work with the competition field though)
Unread 10-01-2014, 11:02
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
A quick way to ensure that your IP address is correct is to open the FRC Driver Station and set your team number in the Setup Tab (also click Choose NIC... OK) prior to starting the cRIO Imaging Tool.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 10-01-2014, 11:20
TEAM1100soft506 TEAM1100soft506 is offline
The runaway renegade of 1100
AKA: Connor Moroney
FRC #1100 (The T-hawks)
TEAM1100soft506 is infamous around these partsTEAM1100soft506 is infamous around these partsTEAM1100soft506 is infamous around these parts
Originally Posted by sasha831 View Post
Hello,
Sasha
What os are you using? In the past the imaging tool has not worked on windows 8.
EX Team member and mentor of TEAM 1100!!! The T-hawks!!!
Finalists WPI regional 2011 along with 177 2011
Winners of the engineering excellence award at Boston Regional 2011
WPI regional 2013 Chairmans award winners
Now the runaway renegade.
Unread 12-01-2014, 22:31
Sasha
Thank You for all your help.
Actually, It turns out that we had to register our FRC vision assistant for 2014. Don't know how that's related, but it fixed the issue
Sasha
Unread 12-01-2014, 22:50
sergioCorral842's Avatar
sergioCorral842 sergioCorral842 is offline
College Student
FRC #0842 (Falcon Robotics)
sergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to beholdsergioCorral842 is a splendid one to behold
Just to clarify, the imaging tool should work on Windows 8, since I configured our team's crio on Windows 8.
Team 842 Falcon Robotics: 2011-2015 (President, Head Programmer, Drive Team)
Arizona Regional Winners: 2012-2014 (Thanks 610, 1212, 1726, 3944, 2486, 2403)
Curie Division Semi-Finalists: 2014 (Thanks 1311, 2013, 2928)
Las Vegas Semi-Finalists: 2015 (Thanks 3495, 4415)
Curie Division Quarter-Finalists: 2015 (Thanks 107, 228, 649)
2015 - 2016: Programming, Drive Team, and Strategy Mentor for Team 3187, The Titans
Studying Computer Science- Software Engineering at ASU (Class of 2019)
Unread 20-01-2014, 22:40
kennethdharmon2 kennethdharmon2 is offline
FRC #1288
kennethdharmon2 is an unknown quantity at this point
sasha831,
We've been having imaging issues as well. And are using the FRC 2013 imaging tool in a work around mode. We have never got the FRC 2014 imaging tool to work. We did not get the LV disc in the KOP, and have back ordered it, in the meantime we installed LV in evaluation mode to get going, then NI gave us a serial number. Your comment about activation, makes me wonder if our LV is not fully or completely activated, and that is the root cause of our issue. Anyone else have a similar experience?
Unread 21-01-2014, 21:47
FRC #1288
On a hunch, and now that our team has the serial number. I did a complete uninstall and clean install of LabVIEW. (Our previous install was in Evaluation mode, with a post install activation). With the new install, the FRC 2014 imaging tool works, and the camera configuration tool works as well. So not for sure, but I think that was our problem.
