Go to Post Hmmm, the Michelangelo method of robot building. Just cut away anything that doesn't look like a robot. - GaryVoshol [more]
Unread 11-02-2003, 22:34
JP_1163's Avatar
JP_1163 JP_1163 is offline
mentor
#1163 (Trojan Horses)
JP_1163 will become famous soon enoughJP_1163 will become famous soon enough
Question Nason pressure switches
There are two connectors on the end of the pressure switch marked C and NC. How do these get wired into the controller so that they can control the pump pressure? Any help appreciated.
Team 1163
The Trojan Horses
Unread 11-02-2003, 23:15
C (for Common) and NC (for normally closed) are the two sides of the switch inside. At low pressure, the switch is closed.
Connect the terminals to a ground pin on the DB-25 connector, and to an appropriate digital input pin (it doesn't matter which of C or NC goes to which of ground or input).
In tyour program, the closed swith appears as a 1, changing to a 0 when the pressure gets near 115 psi. It stays open (0) until the pressure drops to is it 85 psi, then goes to 1, again.
Unread 12-02-2003, 10:32
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
It actually doesn't matter which way you do the NC and C, from what i've tested, because it's a digital switch anyways.
Unread 12-02-2003, 10:49
JP_1163's Avatar
mentor
That sounds great. Thanks for the assistance.
Team 1163
Unread 12-02-2003, 11:29
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Don't Forget
You will need to make a cable that connects into the Digital Input on the controller. We have ours connecting to pins 2 and 6 as labled in the Manual on page 13.
Unread 14-02-2003, 22:26
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Our team is using this switch, and I have a question...
Do we HAVE to wire it up to the RC thrugh the digital inputs or can we just wire it in series with the compresser. The latter would be 1000 times easer, safer, and save about 5 feet of wire. I just have it:
(12v+) --> (COMMON)
(NC) --> (COMPRESSER +)
(COMPRESSER -) --> (12v GND)
and that seems to work fine, it shuts off at 115 psi and there is no programing required. Did I make a big mistake or is this acceptable? thanks in advance - Jacob
Unread 14-02-2003, 23:49
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
(12v+) --> (COMMON)
NO!!!!!!! Not only is this specificly prohibited in the rules, it is also dangerous as the switch is not designed to handle the amounts of current that the compressor draws. ALL switches, sensors, etc MUST be wired to the RC; they cannot control motors directly. Likewise, all motors/compressor must be wired to a speed controller or relay.
Unread 14-02-2003, 23:59
AKA: theshadow
FRC #0620 (WarBots)
whoops
Unread 03-03-2003, 00:27
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
If anyone wires the pressure switch to a digital input, they will simply be disqualified. FIRST specifically states in the checklist that the switch must be wired through a RELAY. I guess i'm going to have to make some modifications next week.
Unread 03-03-2003, 07:21
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
No. You must wire the pressure switch to the digital inputs. Then the RC will turn the pump on and off though a relay. You cannot wire the switch directly to the relay, it specificly says so in the rules.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 03-03-2003, 07:43
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
http://www2.usfirst.org/2003comp/2003inspechecklist.pdf
#38
Pressure switch cannot be wired in series with the pump. It must go through a spike relay.
Unread 03-03-2003, 23:03
#38
Replacing the pronoun with its antecedent, we have:
The _compressor_ must go through a spike.
There are reasons why everything you _can_ do is not something you _should_ do. Maybe the folks at IFI have made sure that First team members are safe from their mistakes, but just because you got away with it, doesn't end it.
The Spike relay is two circuits in one package. The input is an LED which needs the appropriate current and (thus) the appropriate voltage and polarity.
The pressure switch has no source of 5 V, which is what the Spike needs on its input. If you wired the input, via the pressure switch to +12V, which is the only voltage available (except in your electronics) you could
a) apply overcurrent and blow out the LED input to the Spike, or
b) apply high reverse voltage and blow out the LED input to the Spike, thus ruining the Spike.
If you wire the switch to the RC digital input, and put the compressor-controlling Spike on an appropriate output, the Spike is supplied with the design-nominal voltage/current level signal, and the compressor can be officially turned off before and after the match.
The advantages to doing it this way include not being told to rewire and get re-inspected, and not having erratic (or no) operation of the Spike.
Hope this helps.
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
