Go to Post Your entire life is a choice - a choice to believe or denounce everything that is ever said to you. - Amanda Morrison [more]
Unread 10-01-2014, 09:48
Kevins Kevins is offline
FRC #4988
Kevins is an unknown quantity at this point
Double cim motors
Good morning.
We were wondering if anyone could provide insight into exactly what extra components (not found in kits) are needed to double up the cim motors on the kitbot.??
Thanks!
Unread 10-01-2014, 09:52
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The kitbot should contain all of the parts necessary to drive the ToughBoxes with 2 CIM motors.
Unread 10-01-2014, 09:53
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Double cim motors
You will need four identical motor controllers (4 talons, 4 jaguars, or 4 victors, not 3 talons and a jaguar, etc) and the power cables leading to them. In addition, you will need a circuit breaker to put in the Power Distribution Board for each controller. Then, you will need two PWM y-splitters to ensure that both controllers are always putting the same output into the motor. Everything but the two extra controllers are included in the KOP.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 10-01-2014, 11:13
FRC #4988
can you use two jaguar on one side and two victors on the other?
Unread 10-01-2014, 11:17
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
You don't want to do that because each side will but out a different speed and that would make it hard to drive.
Unread 10-01-2014, 11:18
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I wouldn't.
The Jags and Victors have different power curves and responce times.
Our team (FRC Team 1501) use Victors exclusively on drive motors. We haven't had good luck with the Jags.
Although the Talons are good too.
God luck this year.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 10-01-2014, 12:19
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
You'll almost certainly want to have something motorized other than your drive. So split DC motor controllers up such that your drive uses one type and the manipulator(s) uses another type.
The rookie kit comes with two Victor 888's and one Jaguar. You get a Vex / IFI voucher that is good for two more Victors or Jaguars. If you haven't used that yet, get two Victors and then you will already have a set of four Victor 888's.
Otherwise, Vex Pro marked down the price of Victors to $60 for the FRC season. That's quite reasonable based on prices that have historically been charged for motor controllers.
Unread 10-01-2014, 12:35
FRC #4988
I agree. I wish we would have ordered extra victor instead of jaguar, but we already did that....
So what do you recommend between the victor and jaguar for drive motors?
Unread 10-01-2014, 12:38
Mrcope9's Avatar
Mrcope9 Mrcope9 is offline
AKA: Matthew Cope
FRC #3991 (KnightVision)
Mrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of light
Our team decided to upgrade and go with the two speed transmission. We did some research on that, and it seems like it will work out best. Definitely worth the price. You will still need the extra motor controllers, but it will make it faster and more maneuverable than just doubling up on CIM motors.
Unread 10-01-2014, 12:40
Dan.Tyler Dan.Tyler is offline
FRC #2449 (Out of Orbit)
Dan.Tyler has a spectacular aura aboutDan.Tyler has a spectacular aura about
Victor 888 and jags are both acceptable for drive motors. Between the two, I prefer victors.
That being said, we will be using talons this year.
Unread 10-01-2014, 15:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Correction: It will let you choose, on-the-fly, between being faster and more maneuverable OR being slower and more pushy. If all you wanted was faster, it'd have been cheaper to go with a faster gear ratio instead.
Unread 10-01-2014, 16:29
I think by "more maneuverable" he meant better fine control (which you get with greater speed reduction).
