Go to Post Like his father, John V-Neun will soon have the advantage of his head resembling a game object. - Eric O [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 10-01-2014, 13:06
Re: Pneumatic Ball Puncher
Brandon et al,
During inspection, launchers may have to demonstrated for "dry firing" to see if they are in fact safe with no ball present. Having no external hard limit for cylinders quite frankly scares me. While the working pressure is only 60 psi, a cylinder can impart quite a bit of force on the piston and the end assy with no system resistance. I have seen enough catastrophic failures to worry about this design choice. Please prototype with extreme safety in mind.
Unread 10-01-2014, 13:18
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Brandon et al,
While a 3/4" cylinder with good flow to it moves pretty quick, and we always make strong efforts to work and design safely, I would be amazed if an unmodified COTS piston operated at less than 50% max psi recommended by the manufacturer (125psi max, operated at 60psi per FIRST rules) failed due to dry firing. This would be a major design flaw by the manufacturer. Now if we dry fired it at 125+ psi many times and it failed that's another thing. We will of course exercise caution but a failure of this type with no other damage or modification seems implausible especially given the reliability of our product manufacturers.
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 10-01-2014, 13:51
Mike,
125 psi is the working pressure at which integrity with pressure is guaranteed. It does not relate to mechanical failure of the device with no load.
Unread 10-01-2014, 15:36
AKA: Mike Jr.
Mike,
Hi Al, i understand that
I have never seen any documentation from the manufacturer or anyone else for that matter suggesting that this guarantee is under the condition that there is a minimum load applied to the cylinders. A mechanical failure of the cylinder, operated as intended and within the specified psi, unmodified and undamaged/not worn, would be a product or design failure by the manufacturer. These cylinders are designed to be operated under the specified pressure and are not subject to the condition of a minimum load to be safe. Yes they will actuate very fast (especially smaller diameter cylinders) but especially when restricted to 60psi (again less than 50% working pressure) we are well within the scope of intended and safe use specified by the manufacturer.
