Go to Post There are only 4 seasons of the year my friend, build season, competition season, post-season and pre-season. - Tom Schindler [more]
Unread 09-01-2014, 21:42
Parabola Equations
A projectile is launched at x=0 .y=h with speed V and angle θ. What is the equation of the parabola (no air drag)?
y = ax2 + bx + c
a=(g/2)/(Vcosθ)2 ... (g is negative)
b=tanθ
c=h
Given 2 points (x1,y1) and (x2,y2), find the equation of the parabola that passes through the origin and those 2 points
y = ax2 + bx + c
a=(x2y1-x1y2)/(x12x2-x1x22)
b=-(x22y1-x12y2)/(x12x2-x1x22)
c=0
Given 2 points (x1,y1) and (x2,y2), find the equation of the parabola that passes through (0,h) and those 2 points
y = ax2 + bx + c
a=(x1(h-y2)+x2y1-hx2)/(x12x2-x1x22)
b=-(x12(h-y2)+x22y1-hx22)/(x12x2-x1x22)
c=h
Given 3 points (x1,y1), (x2,y2), and (x3,y3) find the equation of the parabola that passes through those 3 points
It gets messy.
Given parabola y = ax2 + bx + c , where a<0, find the value of x and y at the apex
x = -b/(2a) ... y=c-b2/(4a)
Given parabola y = ax2 + bx + c , where a<0, find the value of x and y for which the slope is -1
x = -(1+b)/(2a) ... y = c+(b+1)2/(4a)-b(b+1)/(2a)
someone please check my math
Unread 09-01-2014, 22:12
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Re: Parabola Equations
I'm not sure if that's a challenge, or a dare.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 09-01-2014, 22:58
Reps if you find an error.
Unread 10-01-2014, 10:22
Given the coordinates (xp,yp) of the apex of a parabola whose width is W at a distance D below the apex, find the equation of the parabola.
Name:	Xp Yp D W.png
Unread 10-01-2014, 12:22
Given 2 points (x1,y1) and (x2,y2), and the slope m1 at (x1,y1), find the equation of the parabola.
Name:	parabola 2 points and slope.png
Unread 10-01-2014, 12:54
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
have to ask: did you use LaTeX for those pretty pictures?
Unread 10-01-2014, 13:19
I use Maxima to work out the math. Then I capture a PNG screenshot of the area of interest.
For post#1, all the equations were created using the editing available in vBulletin.
Unread 10-01-2014, 14:56
Given the coordinates (0,h) of the launch point and (xp,yp) of the apex, find the equation of the parabola.
Name:	parabola 0,h xp,yp.png
Unread 10-01-2014, 15:22
Given the values of a, b, and c in the equation y=ax2+bx+c of a parabola, find the launch speed V and launch angle theta if the launch point is at (0,h).
Name:	given EQ find V & theta.png
Unread 10-01-2014, 15:26
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
I give Ether my highest complements. It takes a certain kind of problem for me to voluntarily work on it for about 4 hours. I worked through the 1st, 5fth, and 6th sub-problems relatively quickly, but the middle three are what are stalling me. I have attempted to solve sub-problems 3 and 4 using both systems of equations and using matricies with Cramer's rule. My system of equations was having sign issues (more than can be expected considering I am comparing my solution to Ether's) and my matricies were not working from my rustiness in this area. I will continue to work tonight and post if anything changes.
Once again, props to you, Ether.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 11-01-2014, 00:22
I just finished up the solutions problems in the original post, using three pages of paper in the process. Ether, your solutions check out fine to me (albeit I have very well could have missed something). I also see what you mean by the solution being messy. I think the derivation was messier. To anyone wondering, I solved it each time with a set of matrices and Cramer's Rule. Cramer's rule is both really cool and useful. I advise you all to go check it out. I may try my hand at proving the others tomorrow. Ether, as I stated previously, this is a very good challenge. Thank you.
2015:
2014:
2013:
2012:
Unread 13-01-2014, 12:41
TRWSHSHLX TRWSHSHLX is offline
AKA: Henry Lei
TRWSHSHLX is an unknown quantity at this point
Just finished up all the problems and everything checks out!
I solved most of them using row reduction then the rest were solved using MATLAB. For anyone that's currently taking a class or looking for a refresher in matrices or 2-d kinematics, try these problems out!
