Go to Post The Manual is the "requirements document" for your project. - dlavery [more]
Unread 10-01-2014, 05:35
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Wanna Win More Matches? Try Using Strategy Mats!
I know I already posted this thread on the Rules/Strategy forum for teams to download the strategy mats I made for the 2014 season. I'm posting this here because there may have been some teams that can really use this, who may have members who visit the General Forum more often than Rules/Strategy.
I understand that this may be breaking CD rules, (changed the title and content so technically not the same exact thread) but I'll risk it since I highly encourage, and would love it if all teams in FIRST used strategy mats for matches, whether it's this one, someone else's, or their own. This is why I'm re-posting this in this forum; so it gets more views. I do not see enough of these at competitions, and I want to make this practice more popular. It just makes planning so much easier, clearer, and more productive. Communication is key to working well in an alliance.
Attached is a printer friendly .pdf of what team 701 The RoboVikes will be using for discussing and planning strategies when meeting with alliance members during competition.
You can laminate or slip the sheets into sheet protectors so they may be used with dry erase markers. The RoboVikes have a binder for our drive team coach, and we keep the mats in sleeve protectors, and also have game rules and event maps or information included as well in the binder. Laminating and attaching to a clipboard is another option, but we recommend that teams who wish to use these mats use sleeve protectors inserted in a binder, so strategies don't get wiped off unintentionally. An extra option is blowing this mat up to a large size like ANSI D, printing it on a plotter, laminating, and then attaching to a white board for pre-competition strategy meetings in which the whole team participates.
If there are major errors or problems with the accuracy of the mat diagrams in relation to the actual field construction, please let me know. The diagram is not fully to scale, but just for reference while planning. A problem would be something that would hinder the planning process, like an incorrectly colored alliance station, or a number in the wrong place.
Instructions:
These instructions are to provide a clear understanding of the methods used by the RoboVikes with these mats. These instructions are how we do it, but how you use these mats is completely up to you.
---At the bottom of each full sized strategy mat, you will see sections labeled "Blue Alliance, "Red Alliance," and "Match." Under either color of the alliance sections, there are the numbers 1, 2, and 3. These correspond to a team's assigned operator station.
---To the right of the number, write, in dry erase marker, the appropriate team number that is assigned this station. This will help prevent confusion in station assignments and drive team location with respect to the field and robots, so it is easier to plan starting positions and strategies. Location can change a team's viewing angle of a robot, and teams should be able to anticipate variations in visual difficulty depending on their perspective of the field. Thinking about this is quite important for planning.
---On the line of the section that says "Match" write down the number of the match that will be for that particular strategy.
---There are two full sized strategy mats. One says "Autonomous" at the top and the other says "Teleoperated." These mats are intended to be used for each designated part of the match.
---On the "Autonomous" mat, teams draw with dry erase markers where their robots will start, and what they will do during autonomous, so there is no confusion as to which robot is placed where, and what they are doing to gain points during this part of the match. Generally, directions and movement are indicated by leaders/arrows/vectors. We usually represent shooting a scoring object with a dotted line connected from the target goal to the indicated robot position for scoring.
---On the "Teleoperated" mat, teams draw with dry erase markers the main motions and path that their robot will take in order to gain points. Sometimes it may be necessary to print a second "Teleoperated" mat in order to accommodate more complicated strategies to avoid too much clutter on one mat.
---The mats that have four smaller field diagrams are used for pre-planned plays and strategies. You probably want to print multiple copies of these and have ones designated for offensive and defensive strategies. In our coach binder, we have two dividers for these sections. These are used to draw generic or common strategies so that the coach can use these generic strategies to help aid in ideas for how to plan a particular match. Sometimes these smaller diagrams can also be used for special strategies that can be used in a match where it may be necessary. Pre-planned plays and strategies are useful so the coach does not have to keep wasting time re-drawing common strategies. Red and Blue pens or colored pencils are used to draw on these smaller field diagrams, and are permanent and already drawn before a competition.
---To the right of the "Play/Strategy" label, write a creative or helpful name for the strategy or play for easy identification and quick communication. To the right of the "Description" label, write the basic movements and what is accomplished, and why this strategy or play is used, so the coach can easily explain it to alliance members that are not familiar with the strategy or play.
I hope these strategy mats will be useful for you during your competitions this season! Keep the communication clear between all your alliance members, especially the coaches. All strategies should be collaborated efforts between alliance members, and make sure every single person on the field knows what the heck is going on! I cannot stress enough how clear communication is a vital element to succeeding as an alliance! Lack of communication can rob a team of a win, and is no excuse for a loss.
If you have any questions, feel free to reply or PM me.
Good Luck!
Unread 10-01-2014, 11:45
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Re: Wanna Win More Matches? Try Using Strategy Mats!
This is a great Idea we might have to borrow this idea.
Unread 10-01-2014, 15:58
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
I remember using this with you guys and winning the match! It is very effective and better than just talking about what you will do. Great visual representation!
Unread 10-01-2014, 16:21
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Awesome. I will see if I can get my team to use this. A next step would be to make 8 little magnets representing balls and robots, and then have this mat on a magnetic clip board.
Unread 10-01-2014, 16:46
bEdhEd's Avatar
Great! Borrow to your heart's content! That's the whole point of this thread.
I say it isn't a matter of "might" borrow, but "will" borrow. In my opinion, strategy mats are an essential, and I will never let my alliance go into a match without drawing the idea first.
Unread 10-01-2014, 16:47
bEdhEd's Avatar
My team usually just draws rectangles for robots, but if you think that will work for your team, then have at it.
Unread 10-01-2014, 16:49
bEdhEd's Avatar
Glad to know someone who used mats with me understands their effectiveness. Sometimes miming the moves you'll do and trying to make an imaginary diagram of the strategy in mid air with your hands can sometimes be confusing, and looks silly
I'm sure you can vouch for this idea by saying that it was much easier to understand what was gonna happen on the field, yes?
Unread 10-01-2014, 17:17
Andrew Tucker
AKA: Andrew Tucker
Yes. It will be even more important this year. If you get 3 high powered offensive bots on a team, let alone 2, you are going to need some plan and it will be easier to see this year's game visually rather than talking about it. It will be nice to have set plays to run as opposed to having teams in a general area. This will allow for a more fluid match.
Unread 10-01-2014, 17:24
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
To build on this, start dreaming up plays and write them down, practice the different parts it will get your driver/operator comfortable with the game specific "plays."
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 10-01-2014, 17:28
bEdhEd's Avatar
This is the only thing we didn't do last season, which was physically practicing plays before competition. I made our mats last year only before our third regional, and worked the whole night by myself coming up with plays the night before we flew out for the Colorado Regional, so we never got to actually practice plays, even though we had a good idea on how to do them from just simply showing my drivers.
I'll be glad to make and post my team's strategy mats for the next coming seasons when I can, by the way, so teams don't have to hassle with making their own.
Plus, if anyone ever tells you that FIRST is not a sport, then show them these mats, and ask them how it isn't. It may not be an athletic sport, but it's played just like one, and the athletes are the robots, since they're the ones on the field and really playing the game. The drive team is just there to be the brains.
Unread 10-01-2014, 18:09
Phyrxes's Avatar
AKA: Dave Button
We have traditionally used a whiteboard and markers to do this but this year going the playbook route as getting robots in the right position to minimize cycle time is key.
As someone reading Chief Delphi think of how helpful it would be to hand a rookie or inexperienced team that isn't reading this forum a diagram of the field and be like I could really use your robot "here" and to do "this" so that we have the best shot of winning this match.
It might even save some heated moments in coaching.
Dave Button
Wakefield School
The Plains, VA
Unread 10-01-2014, 18:28
holygrail's Avatar
holygrail holygrail is offline
Gavin Wood
FRC #1939 (The Kuhnigits)
holygrail is just really niceholygrail is just really niceholygrail is just really niceholygrail is just really nice
To take this a step further, for the last couple of years our team has built reduced scale mock fields out of foam board. They are usually three feet long or so and we use hot wheels as robots. It really helps us strategize.
We use strategy sheets at competitions too, thanks for posting these. Nice job!
Unread 10-01-2014, 19:18
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Funny enough, I've been working on something quite similar, but with 3D printed 1:10 scale models. It does end up being significantly larger though. Regardless of whether we print the full field, it's nice CAD practice.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 10-01-2014, 20:17
TheJoe's Avatar
TheJoe TheJoe is offline
AKA: Joe Neyhart
FRC #0279 (Tech Fusion)
TheJoe has a spectacular aura aboutTheJoe has a spectacular aura about
YES!
I would most highly agree, using these (or similar mats) nearly goes hand-in-hand with understanding and subsequently winning matches.
I seen another team use one my first year as driver and thought it was a wonderful utensil for strategy.
The following year I made my own and used it at competition, and we only lost one match during the qualifications (major credit to all of our alliance partners too).
This is a step up from my version, and I think I'll be sure to borrow some of your ideas.
Thanks a lot for that
Unread 10-01-2014, 20:49
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Very nice; clean design. I made my own last year but I will use these this year. Thanks much and I for one forgive your double post.
Alan Gilgenbach
C.O.R.E 2062
