Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 10-01-2014, 16:18
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
Exclamation cRIO Image for 2014 missing
So, I was trying to update the robot for 2014, and I downloaded the 2014 update pack, with the cRIO flash tool. I assumed that the image would come with the tool, but it didn't. Is there somewhere that I'm supposed to download the image? Is there a certain software pack that it comes in?
Unread 10-01-2014, 16:22
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Re: cRIO Image for 2014 missing
You did launch the setup application in the folder after you extracted it?
Unread 10-01-2014, 16:48
Maxwell777's Avatar
AKA: Jackson Gray
The update folder? I ran the setup after I extracted it. I wouldn't have the flash utility if I didn't (I think).
Unread 10-01-2014, 16:54
Kevin Phan's Avatar
College Student
Unhappy Re: cRIO Image for 2014 missing
The image should have come with the tool. I'm not sure where else to help you here.
Unread 10-01-2014, 17:09
The image comes with the programming language update, ie NI, Java, or C++. If you are programming in Java or C++, you also need to install the Java or C++ update.
Unread 10-01-2014, 21:34
Maxwell777's Avatar
AKA: Jackson Gray
Not the Java (We're programming in java) plugin? Oh I see it. Thanks, I wasn't aware that there was an update for the languages.
