Go to Post ...if you don't ask, you won't get. - Billfred [more]
Unread 10-01-2014, 16:52
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Re: To swerve or not to swerve
I think that this sums up pretty well many team's experience with swerve.
...Tried swerve. Didn't move for 1.5 regionals.
http://www.chiefdelphi.com/forums/sh...1&postcount=28
Seriously, the team that posted this has 70+ members, a couple of good years under their belt, and this still happened to them. Don't do swerve if you haven't already prototyped it over the pre-season. I don't really care how big your team is or how much FRC experience you have. Just don't do it.
Unread 10-01-2014, 16:59
AdamHeard's Avatar
Lead Mentor
Originally Posted by aldaeron View Post
#SwerveSoHard
I haven't built one, but I have always wanted to (ask my team). I looked into it quite a bit in the offseason. One of the items that is required (for a Revolution Swerve Style) is a bevel gear set per wheel. I haven't seen these at FRC type stores (AM & VEX). The cheapest place I found them is on Amazon
http://www.amazon.com/dp/B005AVUCJ8/ (straight bore)
http://www.amazon.com/dp/B005AVU6T4 (keyed)
There are a lot of sizes and bores there.
My cautions after doing some research. Compared with other drive styles, Swerve :
- Is more expensive (count up all the miter gears, bearings and sprockets)
- Is heavier
- Is not in the standard WPI library (probably not in LabVIEW either)
- Takes up quite a bit of room in your chassis corners (you have to be able to rotate the whole wheel and all the hardware with it 360 degrees) (it's tall too!)
- Forces a smaller wheel track
A swerve is a significant undertaking and is a potential season breaker (imagine if you can't drive at all!). Make sure you have a backup plan.
Consider your budget and number of team members before committing. Unless you are a huge team it is likely that the effort expended on learning how to build, program and drive a swerve will take away from your other game mechanisms. Essentially the drive train is your main mechanism. Luckily there are some examples (BuildBlitz & Ri3d) to help you build a quick shooter and pickup.
Also not a bad idea to read this from 1114. They address the swerve in some detail http://simbotics.org/files/pdf/drivetraindesign.pdf
I am basing this on the experience of a friend of mine from 1296 who described his experience making a swerve during the build season. It essentially took most of the season's effort. In following years it was easy to do, but the first year and all the lessons learned were tough.
Good luck
-matto-
Vexpro has 3/8" hex broached 15T 12DP bevel gears that are kind of the standard for FRC swerves (starting with 118, then spreading to 1625, 1717, 973, etc...) for a great price.
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
We (1736) had a similar situation in 2012. I wasn't on the team but we ended up locking the swerve modules in place on the Thursday of the regional and driving it tank style.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 10-01-2014, 17:18
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Originally Posted by Tyler2517 View Post
We are running it.
I would imagine you are not the only one, my guess would be the teams with experience are strongly considering swerve. (i.e. 111, 118 , 973 , 1625, 1717)
If they are not doing swerve, many of the top teams are considering butterfly , octocanum and beyond.
Swerve modules are available from 221 if people are interested.
http://www.team221.com/viewproduct.php?id=89
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 10-01-2014, 17:44
Popmaster288's Avatar
Popmaster288 Popmaster288 is offline
AKA: Tim Pop
FRC #0687 (Nerd Herd)
Popmaster288 is an unknown quantity at this point
A swerve drive gives faster strafing and more traction than Mecanum. Depending on what your priorities are, it could be a very good option. If you don't have experience with building swerve drives, then it's a bit too late to start developing one for this season. The only thing that swerve falls short is with potential pushing power. A 6 CIM-6 wheel drive with a ball shifter in low gear will out push a swerve. If the Pro's of a swerve drive outweigh the difficulty of making one, then a swerve drive, in my opinion, is a very good choice.
Unread 10-01-2014, 18:25
AdamHeard's Avatar
Lead Mentor
We won't be doing swerve, as fun as it would be. I can guarantee (off assumptions) that 1717 will be doing swerve though because they're crazy and dance like penguins.
All things equal (motors, rollout ratio, tread, weight, etc...) swerve and 6wd are the same in pushing power.
Unread 10-01-2014, 21:07
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
We built swerve our first year (Rebound Rumble) and didn't really use it since our drivers didn't get much time to learn it. Plus, our drive was kinda glitchy (which could be improved), but I would suggest to pick something with less parts (ie. Butterfly).
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 11-01-2014, 00:10
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
I was on team. Disaster. Mentors trying to save it, students disengaged. Even tank drive was disappointing.
Unread 11-01-2014, 00:25
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
#SwerveSoHard
http://en.wikipedia.org/wiki/Slip_ring
Unread 11-01-2014, 00:41
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
As that team, I can tell you that our performance that year was tough for a lot of us to swallow-- especially the juniors and seniors who spent countless hours not only during the season, but also prototyping and designing before hand. Your team is the only ones who can realistically assess whether you can pull off a swerve drive. We made that assessment and thought we could pull it off, but we were wrong. Be prepared for that if you do end up going with swerve having never tried it before.
If your priority isn't to win competitions and you have little to no experience actually building and programming a swerve drive, it's still a completely valid option for this year's game. Just understand that what you might be gaining in knowledge you will most likely lose in terms of being competitive on the field.
In summary I guess, I can say "Been there, done that, got burned." But sometimes it's necessary to get a bit burned in order to learn a lesson.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 11-01-2014, 03:25
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
The year before i joined my team they tried running swerve or more of a "crab drive". It ended in a way that those member of the team then are still scared to death of trying to run it. We ended up with it falling apart on the field...
Running a swerve is probably the most risky thing you can do but it has great rewards if done right. If you don't have 1000 hours of meeting time to make program and test it in the build season it will be a nightmare to run. If you do try to pull it off have a back up plan and look at the teams who have mastered it and see how they pulled it off some of them even release cad. Even if they do give out cad some times copying it will not work you will not understand why little things were decided apon and may end up costing you dearly in the end.
They also cost a lot of money to buy and the parts can take weeks to arrive even if you built it, but did not have the belts to run it you may not have the programming to make it the best possible.
=No matter what your team is the only one who can decide if you can run it.
Unread 11-01-2014, 11:20
FIMAlumni's Avatar
FIMAlumni FIMAlumni is offline
FIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura aboutFIMAlumni has a spectacular aura about
The best swerves (1717 and 16) are the best drive trains in theory I've seen in first. The 4 downsides to these are reliability, time, weight, driver comfort. If you think you can finish a reliable swerve that fits your weight constraints in enough time to get your drivers used to driving it, I don't see why you wouldn't.
Unread 17-01-2014, 22:32
NickTosta NickTosta is offline
Team 195 Alumni & Former Driver
no team (The Cyber Knights)
NickTosta is an unknown quantity at this point
I doubt you'll see many top teams using a swerve (or mecanum) this year. With a wide-open field, symmetrical game pieces, and many different spots to score from, the additional control and motions you gain from swerve really won't be a significant advantage.
Swerve is a major engineering task, especially for teams who aren't intimately familiar with it (at least one or two successful implementations). The way I see it, you have to be either extremely comfortable with building/programming/maintaining/driving a swerve robot, or you have to be 100% sure that it's going to be a major advantage to have it on your robot. Preferably both.
Originally Posted by shades23 View Post
I see the advantages with a 2 speed being able to our run defense bots and push around others but if you get someone who can operate swerve drive you can practically get out of all sorts of situations as seen with 195 in 2012 and 1717 D'Penguineers... in almost every year recently
<3
Glad to see people from other teams like it and remember it! Swerve is pretty crazy to drive.
Current college student (electrical/computer engineering), former base driver for Team 195
2011 (36-10): WPI Champions, CT Champions, Galileo 13th seed & quarterfinalists
2012 (26-15-2): NYC Finalists, CT Champions, Archimedes 7th seed & quarterfinalists
Unread 18-01-2014, 02:40
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Team 2471 made the decision to go with a swerve drive system this year.
In short, we decided that in this years game it's important to put the robot in the right place on the field facing the right direction, as quickly and efficiently as possible.
It will be a tough rode to go down, but we did have a successful off-season bot with swerve drive this year. we also did a somewhat successful crab drive in 2012.
Some of the disadvantages people have mentioned earlier in this thread not a big issue with the design we are using. We also did a drop center drive bot this off-season. The drop center drive base weighed in at about 36 lbs and the swerve drive base was about 37 lbs. The modules weigh 7.5 lbs each, only take up a 6" by 6" square, the wheels touch the carpet 2" in from the edge of the robot, and they only cost 222$ per corner.
