Go to Post Brandon is my hero :) - Cory [more]
Unread 08-01-2014, 16:13
kakugyou kakugyou is offline
FRC #3543
kakugyou is an unknown quantity at this point
Smile Help for LV-MaxSonar-EZ1
Hello!
My team and I have been looking for programming codes, wiring ideas etc. for our LV-MaxSonar-EZ1. All help is appreciated
Unread 08-01-2014, 16:18
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Re: Help for LV-MaxSonar-EZ1
Originally Posted by kakugyou View Post
Hello!
First of all what do you plan on using it for? There are a lot of things you could use a sonar sensor for this year.
Unread 08-01-2014, 22:42
DonRotolo's Avatar
Back to humble
FRC #0832
I have been successful using the Analog output of the sensor wired to an Analog input on the Analog Breakout of the cRio to measure distance. The voltage is proportional to the measured distance. Programming should be straightforward (but I am not a programmer)
Of course the sensor needs power & ground to function.
Unread 08-01-2014, 22:52
The LabVIEW example finder has an example for the EZ1 using analog. Like all of the NI FRC examples, it not only has code, but wiring pictures.
Unread 10-01-2014, 16:32
FRC #3543
We plan on using the sensor for measuring the distance to the wall. Thank you for the reply!
Unread 10-01-2014, 16:36
FRC #3543
Would you mind elaborating that please? Our team doesn't have much expertise in that division. (We have almost no expertise actually)
Thank you all for your help!
Unread 10-01-2014, 17:31
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
You'll want to use a PWM cable cut in half to connect the sensor to the Analog Breakout. One end of the cable should be the female end and the other end should have 3 bare wires.
Red wire should go to the +5 pin on the sensor. Black wire to GND on the sensor and white wire to AN on the sensor. You'll need to solder all 3 connections. The connector end of the cable goes into the Analog Breakout. Black wire to GND, red wire to +5v and white wire to SIG.
In software, you'll need to find the AnalogVoltage (or something similarly titled) function. I can't help you much beyond that, since I'm not familiar with LabView.
When you read a voltage, every .0098 volts equals one inch. The relation is proportional.
Unread 10-01-2014, 18:00
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Fortunately the EZ1 has multiple outputs to choose from. Personally I prefer the PWM signal.
Additionally, LabView has an example on how to use it with this method.
Once LV is open, select the Support tab on the left (See image 1)
Next, select Find FRC Examples. (Again image 1)
Expand the "Sensor" branch, and open the "EZ1 M1010 Sonar Digital.lvproj". (Image 2)
When you have the example open, you will see all the details you will need to get it to run on your robot. (Image 3)
Name:	Find Example.JPG
ID:	15801  Click image for larger version
ID:	15802  Click image for larger version
Unread 11-01-2014, 02:28
Average Joes Average Joes is offline
None #3620
Average Joes is an unknown quantity at this point
Hi guys,
I'm wondering whether anyone can post images of each step (programming code and wiring pictures) from the LabView example for the EZ1?
I'm curious as to how I can wire the EZ1 to the cRio and would appreciate any help.
Thanks in advance
Unread 11-01-2014, 02:32
Andrew Tucker
AKA: Andrew Tucker
Keep in mind that anything in front of the sensor, it would be best to use the vision tracking that way you can get a value that won't change based on elements on the playing field.
Unread 11-01-2014, 07:14
I'd be willing to post some pictures from the LV example, but perhaps a better approach would be to install it and experiment with it yourself. It is useful to have a second SW tool that you can use to verify if a sensor works, how well it works, "is it the code or the sensor", etc. I have nothing against printfs. But sometimes a panel is worth a thousand printfs.
Greg McKaskle
Unread 14-01-2014, 13:04
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
we were after the screen shot just for the wiring diagram, but we can glean that from the email thread (+5V, GND, and either the PWM or AN)....
