Go to Post I'm looking forward to seeing it in action! That is one sweet looking gun. The look on his face has me a tad worried though.... - Zholl [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
  #31   Spotlight this post!
Unread 06-01-2014, 00:22
dtengineering's Avatar
AKA: Jason Brett
Re: How do we launch this thing? 2014
Jim has posted some really good suggestions here... this is, largely, a solved problem. Many teams found a way to launch balls in 2008 that were similar to these ones, but larger and heavier.
Dig back in the forums and videos and team websites if you weren't around FRC in '08.
And watch the BuildBlitz and Robot In Three Days (and a snowstorm) for ideas.
It isn't a question of how, so much as how to do it most efficiently!
Jason
Google: FRC 2008 launcher or maybe FRC Overdrive Launcher and check out the old videos and websites.
  #32   Spotlight this post!
Unread 06-01-2014, 01:42
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Originally Posted by MMahoney View Post
I built a quick prototype pneumatic launcher today and was disappointed by how weak it shot. We did a variety of tests at different angles (~10 degrees, 45 degrees, and ~75-80 degrees) and found that the ball flew about 6-7 feet at highest. Barely enough to clear the truss.
One issue with a pneumatic cylinder launcher is the peak piston velocity being restricted by the rate at which air ahead of the piston can exit the cylinder.
Ideally, the space in front of the piston disk seal would be a vacuum, and offer no resistance. This could be accomplished by sealing both ports of the cylinder with the piston extended.
Then by mechanically pulling the piston back into the cylinder so as to build up pressure on one end and partial vacuum on the other piston exit end, you can make it into a "gas spring"
Releasing the hold on the compressed piston would fire it at a higher speed than when there is air ahead of the piston.
This may not be legal though. There are many safety issues. Too much piston retraction could build up pressure in the cylinder exceeding its limits.
Also, piston can overshoot inside cylinder and impact the head at the exit end, damaging it.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
  #33   Spotlight this post!
Unread 07-01-2014, 14:23
Johnson.2937's Avatar
Johnson.2937 Johnson.2937 is offline
FRC #1248 (Berea Midpark Titans)
Johnson.2937 is on a distinguished road
Originally Posted by TucoSalamanc View Post
Too bad full-field tosses are illegal, because this thing is beastly.
Can you reference a rule that says this?
  #34   Spotlight this post!
Unread 07-01-2014, 14:32
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Per the scoring section of the manual:
A BALL is considered SCORED in an ALLIANCE’S GOAL if
  • a ROBOT causes one (1) of their ALLIANCE’S BALLS to cross completely through the opening(s) of one (1) of their ALLIANCE’S GOALS without intervening human contact,
  • the ALLIANCE ROBOT last in contact with the BALL was entirely between the TRUSS and their ALLIANCE’S HIGH GOALS, and
  • the BALL is not in contact with any ROBOT from that ALLIANCE.
Emphasis mine
  #35   Spotlight this post!
Unread 07-01-2014, 15:13
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
There may be a way to get pistons to work. You guys have only thought about if pistons applied force directly. What if the pistons pulled the ball instead of pushed it? Just a thought
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
  #36   Spotlight this post!
Unread 10-01-2014, 21:49
BenCogs BenCogs is offline
FRC #4200
BenCogs is an unknown quantity at this point
I am very interested in seeing this video, could you please link it for us?
