Go to Post A video is worth 30,000 words a second. - Thromgord [more]
Unread 09-02-2003, 16:10
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: Transmissions and Drive Train
Unread 09-02-2003, 16:11
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
Nice, where did you obtain your treads and the rollers for those treads?
Very nicely put together.
pi is exactly 3
IM me at: zmstr265
Unread 11-02-2003, 13:43
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
We made the rollers, I don't think we can release the treads.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 11-02-2003, 13:45
Lauren Hafford Lauren Hafford is offline
#0159 (Alpine Robotics)
Lauren Hafford is an unknown quantity at this point
Send a message via AIM to Lauren Hafford
SEXY!!!!!
i only wish our drive train was that shnazzy! ours is kind of...jerryrigged...i guess...:-)
lauren
Unread 11-02-2003, 14:06
Matt Reiland's Avatar
'The' drive behind the drive
Question to team 45 on the mounting of the air shifter:
It looks like you have screwed into the end of the cylinder that contains larger threads and the pin. Is this cleared somewhere in the rules? When we were going to do the same thing our interpretation of this rule
M16 Pneumatic components supplied in the Kit (pump, regulators, pressure switches,
cylinders, valves, fittings, tubing, etc.) may not be modified except as follows:
· Tubing may be cut.
· The wiring for the valves and pressure switch may be modified as necessary to
interface with the rest of the control system.
· Mounting and connecting pneumatics components using the pre-existing
threads, mounting brackets, etc., is not considered a modification of the
components.
Seemed like drilling and tapping into the end of the cylinder was considered a modification. Just wondered if there was an update I don't know about.
Unread 12-02-2003, 00:14
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Hmmm
Matt,
Good point. This needs investigated.
I do know that teams have been allowed to alter this portion of the cylinders in order to mount them to their 'bot. I think that this rule has always been in the FIRST manual, but there has also been a clarification in years past that allows for alterations of this part of the cylinder.
Once I find out the details, I'll post. I assume that other teams will want to do something similar.
<edit>
OK... I checked the official jive site and FIRST will not allow this. Matt, thanks... I am glad that you pointed this out. We would much rather change this now than at the competition.
FIRST's answer
But... for what it is worth, I see no harm with altering that portion of the cylinder. We are still a good 1/2" from the air chamber... sheesh! Oh, well.
<edit>
Andy B.
Unread 12-02-2003, 09:52
Uhhhhhh, we are also in violation to the ruling you showed Andy since we used the existing threads on the body end but it required removing the pin. I hope they can clarify this a little better.
Unread 12-02-2003, 10:32
President, VEX Robotics, Inc.
Andy & Matt - Here Is What We Did
O.K. guys, we actually nitced that rule and made our details accordingly. By the way the CTT (Crazy Techno Transmission) is what we are callin gour version, but it is still a TechnoKat ripoff. I have attached a dxf file of our detail for your reference. I will even offer to have our machine shop make it for you, if you'de like.
It takes the shift shaft and connects it to a 4mm ID bearing. The bearing is held by clip rings.
E-mail me if you want more details.
-Paul
Unread 12-02-2003, 10:43
Paul, Is your detail for the Body end or the Rod end?
Here is what ours looks like after the detail I made, it didn't modify the cylinder but it required the pin to be removed so it could be threaded on to the end of the cylinder body.
Unread 12-02-2003, 10:50
Rod End
Matt,
My detail is for the rod end. We are using 2 cylinders, not 1. Your implementation could not use my detail, sorry.
-Paul
Unread 12-02-2003, 12:20
Well this sucks, I just got a response from FIRST
Reply:
When we examined the cylinders that we had in stock, we thought that the
end pins were more than lightly pressed into the cylinder bases. We
envisioned teams clamping the cylinders in vises and driving the pins
out. Because we had the "no-modification rule", and did not want teams
criticizing us for another rule change, mid stream, we stuck to it and
issued the response quoted above. Rule M16 did not specifically state that
you could not remove the pin. The Forum posting by FIRST clarified the "no
modification of pneumatic components" statement in M17 by explicitly
mentioning the pin. By removing the pin, you have modified the air cylinder.
36F
Looks like I have to modify my mount to put the pin back in, shouldn't be that bad I guess just a waste of my time
Unread 12-02-2003, 14:14
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
We ground down the pin while it was still in the cylinder. So it's still there... kind of.
What do you think the ruling on this would be?
Unread 13-02-2003, 09:35
I Would Say It is a Modification
I would say that it is against the rules.
Unread 13-02-2003, 11:33
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
John,
Sorry to say, I agree with Paul. I realize that it may be alot of work to undo something like that, but better now than later.
I seem to recall a saying about the wise man accepting correction while the fool curses his luck (at getting caught). In the Proverbs perhaps?
Based on your previous posts, I assume you're doing the wise (and graciously professional) thing.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 13-02-2003, 17:38
JVN JVN is offline
@JohnVNeun
Sigh...
We're ordering a new cylinder, and switching them out in the pits at UTC. This seems to be the best solution given the circumstance.
Paul-
Thank you for your opinion, your comment weighed quite heavily in my decision.
ChrisH-
Even the best teams skirt the rules every now and then, but we don't agree with that, so we try to keep everything well within the bounds of gracious professionalism. So we'll certainly be doing the wise thing and replacing it. Thanks.
This is what design constraints are for, right?
Thank you all for your comments.
I thought I was fairly well in touch with the rules/updates, but I didn't even notice this ruling. I wonder how many other teams will be simliarly affected.
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
