Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Go Back   Chief Delphi > Technical > CAD
Unread 11-01-2014, 06:09
raafaelsDbug's Avatar
raafaelsDbug raafaelsDbug is offline
AKA: Rafael Sherbu-Cohen
FRC #3316 (D-Bug)
raafaelsDbug is an unknown quantity at this point
FR8ZZ-Hex bearing CAD
Hi!
I am looking for AndyMark's FR8ZZ-Hex bearing CAD: http://www.andymark.com/product-p/am-0279.htm
Where can I find it?
Does the center part of the bearing protrude from both sides?
Thanks,
Rafael
Unread 11-01-2014, 07:04
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: FR8ZZ-Hex bearing CAD
Go to www.3DContentCentral.com. There are over 500 FRC/FTC parts here.
http://www.3dcontentcentral.com/down...=171&id=225520
You can download in any file format you wish.
For use of AndyMark products in an assembly, in SolidWorks format go to
www.solidworks.com/FIRST. Download the SolidWorks FIRST KOP
The FR6ZZ and FR8ZZ bearings are located in the KitBot>AM14U Long or AM14U Wide folder of the complete KIT bot assembly.
If you are using SolidWorks, download the parts into a Design Library folder. That way you can just click and drag the bearing into the assembly window. If you hold down the Alt key, the bearing cylindrical face will mate to the cylindrical face of an axle or hole.
Marie
