Go to Post A stack of hearing aid batteries can also read 13v, but they won't run a robot. - Alan Anderson [more]
Unread 10-01-2014, 22:47
Gearheads1 Gearheads1 is online now
AKA: Brian Holmgren
FRC #4455 (The Burger Bots)
Gearheads1 is an unknown quantity at this point
Changing autonomous routes through driver's station software
We're a second year team with a single programmer and no strong Labview mentor. Our programmer is sure that he can make some software switches in driver's station and choose one of them after we have placed our robot on the field and it will affect how our autonomous works. I don't think the driver's station can communicate with the robot until teleop, and the only way to change routes in autonomous is through a switch hardwired to the robot that would allow you to tell the autonomous code which routine to run. Any help sorting this out would be greatly appreciated.
Unread 10-01-2014, 23:09
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Re: Changing autonomous routes through driver's station software
During Autonomous, the robot still communicates with the computer, reporting that it is in Autonomous state and reading joystick values, if you tell it to. This does not mean that you cannot still control the robot's movements. You can use a switch or a potentiometer in your control system to tell Labview what autonomous instructions to run, just like using a joystick in teleop. The only thing is, you have to have this switch set correctly before the match starts so that you don't have to touch the controls. The robot will start autonomous, read the switch, then run the program without you touching anything. This is how some teams were able to make one autonomous program with instructions for two or more different starting positions in last year's game.
Definitely possible and a good way to be flexible and work with your alliance!
Happy building!
BTW: The robot is in communications with the computer from the time you see a camera input, until you unplug your driver station from the FMS.
Per Audacia Ad Astra
Unread 10-01-2014, 23:13
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
You can set up multiple autonomous modes using the Digital Inputs on your driver station, shown below.
The example autonomous mode already has the Digital Inputs in the code, you just have to make the case structure, and then have your autonomous code in there.
The switches just have to be set before the match starts.
Hope this helps.
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 10-01-2014, 23:37
AKA: Brian Holmgren
Thanks for the quick, and great, responses. I will let our programmer know that he's the man!
Unread 11-01-2014, 07:20
To add to this. The information above is correct. The I/O values on that tab will mirror the Cypress settings with a Cypress is plugged in, but are inputs when no Cypress board is used. These virtual I/O values are transmitted to the robot and I believe they are latched during auto. So set them during disabled period before the match starts.
The other approach is to use network tables or smart dashboard variables. This is somewhat more flexible, but not necessarily better.
Greg McKaskle
Unread 11-01-2014, 10:10
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
We use the analog slider, but i couldn't tell you how they worked (I don't know how they work in the code)
2015 MAR District Champions
Unread 12-01-2014, 21:55
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Greg McKaskle
Do I infer from this that at least one DS packet is sent to the robot at the beginning of Autonomous?
We had a problem last year when our autonomous code was looking for a motor speed from the DS via an SD call. In testing, autonomous worked fine. On the field, it never did anything.
Maybe I just answered my own question. Does the DS data get sent in autonomous, while the SD data is not?
Tim Jordan
Software Mentor
3853 Pridetronics[
Unread 13-01-2014, 21:47
Smart Dashboard (SD) is entirely independent of the DS and field modes. It will operate from the time the client(s) and server init until they shutdown. It operates between dashboard and robot and the DS in not an SD client.
The DS and robot are in constant communication during disable, auto, and tele. But during auto, the joystick data will not make its way to the user code, and neither will the Cypress I/O. The joystick and Cypress data will be the last packet received during disable.
Greg McKaskle
Unread 14-01-2014, 22:51
Tim
FRC #3853
Ah, just dug up the code. We were looking for the throttle position from one of the joysticks.
Thanks Greg!
Software Mentor
3853 Pridetronics[
