Thread Tools |
Rating:
Display Modes |
#9
Re: Solenoid valve troubles
Last year our team use festo valves and they had the worst screw in fittings into the actual valve itself as well as the worst electrical connections. The fittings you had to lock tight the fittings and actually break open the casing and individually solder the wires to the leads. What specific problem are you having?
