Go to Post Crazy is relative - dtengineering [more]
Unread 11-01-2014, 08:24
stveception stveception is offline
FRC #1660
stveception has a spectacular aura aboutstveception has a spectacular aura about
Motion of Projectile App
I wrote a javascript app that visualizes the motion of the ball with adjustable parameters like angle and initial velocity. The app seems to work best in Chrome.
http://hostedfiles.x10.mx/2/2014ball.html
Please feel free to let me know of any issues with the app. Also, you can double check my maths to see if I made any mistakes. I used the formulas from here
I wasn't sure of the terminal velocity. The terminal velocity parameter is used to compute the amount of drag on the ball. Currently the value I'm using is 51.33 which I found is the terminal velocity of a volleyball, so its likely going to be less than that.
Unread 11-01-2014, 11:11
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Edxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant futureEdxu has a brilliant future
Re: Motion of Projectile App
Thanks for making the App!
I just want to know, would it be possible for you to change the input such that we can type in our own figures, instead of using the dial, to increase calculation accuracy?
Unread 11-01-2014, 11:17
blaze8902 blaze8902 is offline
AKA: Buddy McWilliams
FRC #4265 (Secret City WildBots)
blaze8902 is on a distinguished road
I believe the terminal velocity is closer to 11.37 m/s.
Edit: That's 36.09 f/s. Sorry, I've always been taught to do all my physics in metric.
Unread 11-01-2014, 11:19
jertel's Avatar
jertel jertel is offline
FRC #0706 (Arrowhead Robotics)
Team Role: Electrical
jertel is an unknown quantity at this point
Nice work. I couldn't have programmed that.
I do agree with Edxu that changing the values via keyboard instead of a scroll bar would be more convenient. Would your math still work with decimal values?
Unread 12-01-2014, 15:35
FRC #1660
Done!
Unread 12-01-2014, 16:47
RoboticWombat's Avatar
RoboticWombat RoboticWombat is offline
Doctor Robotic Wombat Is In!
AKA: Luke Baker
FRC #4342 (Demon Robotics)
Team Role: Tactician
RoboticWombat is an unknown quantity at this point
Thumbs up Re: Motion of Projectile App
Thank you for making this app. It will be very helpful.
Unread 12-01-2014, 17:54
Originally Posted by stveception View Post
I used the formulas from here.
Caveat utilitor. Quoting from the source:
Suppose, further, that, in addition to the force of gravity, the projectile is subject to an air resistance force which acts in the opposite direction to its instantaneous direction of motion, and whose magnitude is directly proportional to its instantaneous speed. This is not a particularly accurate model of the drag force due to air resistance (the magnitude of the drag force is typically proportion to the square of the speed),
For a given launch speed, you can probably empirically find a value for "c" which is a good compromise. But if you change the launch speed significantly, that empirical value for c may no longer be a good approximation at the changed speed.
It would be interesting to compare the results of the above model to other models recently posted here on CD which implement drag proportional to speed squared.
