Go to Post 27 ft/s? They must really "Rush" around the field - Michael Corsetto [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 11-01-2014, 13:56
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: Build Blitz Robot Reveal - Team Copioli
I saw posted somewhere here on CD(maybe in the 2014 VEXPro product release thread) that the pulley is toleranced such that 2 9mm belts will fit on the 15mm pulley.
Unless I imagined seeing it.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 11-01-2014, 14:05
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Switzer96 View Post
Not sure if I'm missing something but I was going through Team Copioli's CAD files, and it appears as if they are using a 15mm timing pulley (P/N 217-3230) to drive two belts out of the gearbox. The belts are not in the design, so I am trying to figure out how two would fit with what I'm assuming is a 9mm timing belt from vex pro. Are they using a different pulley/belt or would this be able to fit somehow?
I hope that more information on assembly will be released soon for teams looking into using Vex Pro's versa chassis system.
The 15mm pulley is a bit wider than that, and the 9mm belts are a bit narrower than that, allowing for two "9mm" belts to fit on a "15mm" Vex pulley.
Unread 11-01-2014, 14:10
Switzer96's Avatar
Switzer96 Switzer96 is offline
AKA: Cameron
FRC #1806 (S.W.A.T.)
Switzer96 is an unknown quantity at this point
Ok, I found where this was discussed in the Versa Chassis thread. RC responded to a similar question - http://www.chiefdelphi.com/forums/sh...1&postcount=11
-The pulleys can be expanded with spacers.
Unread 15-01-2014, 10:53
Aren_Hill's Avatar
Build Nifty Things
The 42T and 60T pulleys can we widened with spacers. The 18T, 24T, 30T, 36T pulley come in two widths, the wider one can accommodate two 9mm wide belts. (we toleranced things to make this work).
A guy who likes robots.
