Go to Post Okay, Okay, I officially apologize to the the entire country of Canada - Joe Johnson [more]
Unread 11-01-2014, 18:22
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
Pulling Firing Pin
Okay so after some discussion on CD on another thread my team and I feel like we are pretty close to nailing down a design. The big issue we have right now is being able to pull the pin when there is large forces pulling on it. Let me. Try and explain what our plan is. We are going to have a Claw pick up and hold the ball. A surgical tubing "sling shot" will be pulled back by a pneumatic piston. We want to fire the "sling shot" by pulling the pin on the linkage between the surgical tubing and the piston. The issue is we are going to try and get 50-60lbs worth of force when the surgical tubing is pulled back. That is going to make it next to impossible. What my question is, is there any special linkage that can be easily pulled even though it is pulled on by large forces. Thank you for any help you can provide.
Unread 11-01-2014, 18:27
Dr.Gusta's Avatar
Team Role: CAD
Re: Pulling Firing Pin
One thing I was thinking about is you can claim a piston from the KOP that has a 2in bore but only a 1in stroke. At 60psi that is 120lbs of force. The just use the piston shaft as the actual pin.
Unread 11-01-2014, 18:34
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
We used a fence gate latch on our 10 point climber in 2013 and plan to use one again this year. Pulling on the "fence gate" part will not cause it to open unless it is unlatched. A small pneumatic cylinder can slide the latch open and closed.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 11-01-2014, 18:37
Adamz_'s Avatar
Adamz_ Adamz_ is offline
Who wants coffee?
AKA: Connor Adams
FRC #4519 (Kings Mechavaliers)
Adamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to behold
i just want to say that is one of the best ideas ive heard in a while
2016 North Bay Regional Finalists
2016 Greater Toronto Central Regional Semi-Finalists
2015 Windsor Essex Great Lakes Regional Quarter-Finalists
2014 Windsor Essex Great Lakes Regional Semi-Finalists
2014 Waterloo Regional Quarter-finalists
2013 Waterloo Regional Highest Rookie Seed
2013 Waterloo Regional Rookie All Star Recipient
Unread 11-01-2014, 18:38
Jared Russell's Avatar
Taking a year (mostly) off
How did you compute 120lbs of force?
Unread 11-01-2014, 18:43
Jared's Avatar
Jared Jared is offline
A piston with a two inch bore has a radius of 1 inch, and an area of pi inches.
F=PA=(60 lbs/in^2)(pi)(1 in^2) = 188.49 lbs.
Unread 11-01-2014, 18:45
Dr.Gusta's Avatar
Team Role: CAD
That is a really good idea actually, super simple yet very effective. Thank you. As for the 120lbs of force 60psi of air pressure. The area of the 2in bore is a little less than 2 square inches. 60 pounds per square inch × 2 square inches = 120lbs of force. It is not exact but close enough.
Unread 11-01-2014, 18:46
Dr.Gusta's Avatar
Team Role: CAD
He beat me to it. I was typing my reply when he posted that. He did the math and all.
Unread 11-01-2014, 18:57
gurellia53's Avatar
word up
AKA: Andrew G
The fence gate latch is simple, effective, readily available, and $6.
A long bolt can be used instead of the bar piece for different mounting orientations.
Its not complicated at all, but I'll take a picture of our '13 mechanism on Monday.
FRC
Unread 11-01-2014, 20:00
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
We used that same latch in 2010 "Breakaway" to release our kicker. It was one of the most reliable parts of the robot.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 12-01-2014, 11:04
DonRotolo's Avatar
Back to humble
FRC #0832
Ditto.
One can modify the design slightly such that releasing a very large load needs only a small force. Commercially there are latches that can release several tons with a pull string.
Unread 12-01-2014, 11:22
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
X3 Cheap, easy and effective.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 12-01-2014, 14:34
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Here is a nice design used in saling.
http://www.westmarine.com/webapp/wcs...7#.UtLpcfRDt8E
http://www.westmarine.com/webapp/wcs...7#.UtLqDvRDt8E
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
