Go to Post We call ourselves community/family. We are. Our kitchen table where we gather is the size of Chief Delphi. - JaneYoung [more]
Unread 11-01-2014, 18:24
Silver's Avatar
Silver Silver is offline
Rookie
AKA: Digby Baker-Porazinski
FRC #5236 (Man O' War)
Team Role: Tactician
Silver will become famous soon enough
Question How much air can be stored onboard?
My team feels like we're going to have so many pistons sucking up so much air that we'll run out. I was asked to scan the manual for a max storage limit on the robot, but I found none. Anyone know how much air we can store in tanks onboard our robot?
Also, if we have a compressor onboard, can we still precharge the storage tank(s) before autonomous?
Thanks again,
Team 5236 - Man o' War
Unread 11-01-2014, 18:28
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: How much air can be stored onboard?
There's no limit in the rules, though you're obviously limited by space, weight and cost.
The tanks are normally filled before autonomous, whether or not a team has a compressor..
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 11-01-2014, 18:30
Adamz_'s Avatar
Adamz_ Adamz_ is offline
Who wants coffee?
AKA: Connor Adams
FRC #4519 (Kings Mechavaliers)
Adamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to behold
Hey there! Ill do my best to answer what i can. I know that you are allowed to pre-charge your air tanks when your are queing for a game. As for how much air you can store, i don not think there is a limit to how many tanks you can have, you just have to make sure that all the pressure in the tanks is 125 psi max, and the psi everywhere else is 60.
Good luck this year!
2016 North Bay Regional Finalists
2016 Greater Toronto Central Regional Semi-Finalists
2015 Windsor Essex Great Lakes Regional Quarter-Finalists
2014 Windsor Essex Great Lakes Regional Semi-Finalists
2014 Waterloo Regional Quarter-finalists
2013 Waterloo Regional Highest Rookie Seed
2013 Waterloo Regional Rookie All Star Recipient
Unread 11-01-2014, 18:36
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
one4robots is on a distinguished road
One small correction...max storage is 120 psi. All pneumatics components must be rated for 125 psi or better.
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
Unread 11-01-2014, 18:50
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
One more small addition, while this is right it probably is near impossible...
According to R80: Off-board compressors are permitted, however the compressor must be controlled and powered by the ROBOT.
This means that, due to the required pressure switch, this pressure will more likely be somewhere between 108 and 118 psi. The only way our switch has ever allowed 120 psi is when an inspector shorts it to test the relief valve. The one we used last year was our best of the three we have, and it only would reach 109 psi. The worst one shut off around 92 psi.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 11-01-2014, 18:52
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Maximum working pressure is defined as 60 PSI, but you may choose to use less or get fancy with multiple branches at different working pressures. The lower bound of working pressure is defined by the solenoids used.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 11-01-2014, 19:11
Talking Re: How much air can be stored onboard?
For a 28" x 28" x 60" robot, you can theoretically store 47,040 in^3 of air onboard.
The problem, of course, lies in all the structure and electronics required to actually HOLD the air, some of which are required, which displace some air as well as removing some air storage capacity. Actually pressurizing the air will need some thicker material, thus even less storage capacity.
Oh? The air actually has to DO something? That complicates things. See previous paragraph.
(If you can't tell, this post is not intended to be serious. Sometimes, the GDC will get a question similar to the first one on some other component, and answer with something like the above.)
Unread 15-01-2014, 15:06
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
At Crossroads we (the inspectors) would watch for teams with carts that had compressor other then the legal KOP compressor. If they used them in que to charge their robot, they would be in violation of the off robot compressor rule. You have to use the KOP compressor to fill your robot. Period.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 15-01-2014, 15:11
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Note that you are allowed to use one battery to charge the compressor and replace it with a fresh battery before going on the field. (Q88)
Unread 15-01-2014, 16:48
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
As a practical matter you are limited by the rate you can charge your reservoir with your legal compressor. In elimination matches, the cycle times get shorter along the opportunity to recharge your system between matches. Consider having to start a match with a discharged system. With more storage volume, it takes longer to bring up your system to a usable pressure. Sometime less is more here.
Unread 15-01-2014, 17:24
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Keep in mind that the more capacity you have, the longer it will take to re-charge when depleted. Sometimes it's better to have less storage that reaches full pressure faster.
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 15-01-2014, 17:27
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
R79 - Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate.
You are not required to use a specific "KOP" compressor - but the one you use must comply to R79.
As far as the "offboard" allowance - this really does not change the pneumatic circuit - just puts the compressor in the pit, or on the cart. Space and weight savings at the expense of not recharging during the match.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 15-01-2014, 18:25
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
In theory infinite. In practice the maximum will be around 2 gallons given the highest compressing legal compressor. Our robot last year was all air to climb the pyramid. We did numerous tests and if you want to charge in 5 minutes, 2 gallon worth of air is the max. During eliminations you will only have 5 minutes between matches as you win unless you burn your one time out.
Unread 15-01-2014, 19:07
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Some thing else to consider is; where is your compressor?
When it is on the robot during a match you may store 120 psi but when the compressor is NOT attached to the robot you may only store 60 psi.
Unread 23-01-2014, 20:15
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
I don't think thats entirely true. This is only if your regulator is off the bot as well. See R86
