Go to Post A lack of knowledge is okay; a lack of initiative to learn more is not. - Madison [more]
Unread 11-01-2014, 23:51
CheerlessBear's Avatar
CheerlessBear CheerlessBear is offline
AKA: Alexander
FRC #3082 (Chicken bot pie)
CheerlessBear is an unknown quantity at this point
Re: 3336 Catapult Prototype
My team was able to make an effective catapult by using surgical tubing and 80-20 and that worked fairly well.
Unread 12-01-2014, 00:08
Physicguy's Avatar
Physicguy Physicguy is offline
It exploded on its own I swear...
AKA: Jeffin James
FRC #2582 (Pantherbots)
Physicguy is just really nicePhysicguy is just really nicePhysicguy is just really nicePhysicguy is just really nice
I would have to agree...speaking from experience trying to use pneumatics to drive your catapult may not be the best idea. You may want to explore a combination of surgical tubing and pneumatics would probably give a better result. Our team is trying a pure motor driven catapult.
Unread 12-01-2014, 00:18
AKA: Alexander
My team originally tried pneumatics and we couldent achieve the speed we needed so we tried other designs. But we have not tried purely motor driven may I ask how you are implementing it?
Unread 12-01-2014, 00:36
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
We had success with our purely pneumatic catapult prototype. The key is using a lever and pulling down on the opposite side of the catapult instead of pushing up; this gives it more speed and with pneumatics you have power to spare.
Unread 12-01-2014, 06:01
FRC #1836 (MilkenKnights)
Based on how pneumatic works, they should push and pull at the same speed. You are likely getting better results because you are pulling closer to the fulcrum then you were pushing or because your pneumatic cylinders are acting at a better angle.
Unread 12-01-2014, 07:29
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
This may not actually be correct.
There is more pushing force in the pneumatic cylinder as there is more surface area on the piston being pushed by the air. There is less force when retracting (pulling) due to there being less surface area on the piston face. This is due to the shaft attached to the piston.
While this may not sound like much it can be significant depending on what you are trying to accomplish.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 12-01-2014, 08:39
I didn't think about that, but you are correct. Regardless it is unlikely that Aroki's success is correlated with pulling instead of pushing but rather the angle and position that the pneumatic cylinders are pulling at.
Unread 12-01-2014, 17:39
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
However -- Pulling is going to gain a great deal of speed due to the volume needed to fill the cylinder is reduced. I understand you can gain the same speed pushing by introducing the exhaust from the solenoid back in with the input air -- have not tested it, but will tomorrow.
Unread 13-01-2014, 01:27
Or you can push with smaller cylinders
Unread 13-01-2014, 02:09
Aroki's Avatar
Team Role: CAD
I worded my response earlier pretty poorly, I wasn't talking about the difference in speed/power between a cylinder going in or out. I was merely making a point about using a lever to account for the slower speed of pneumatic cylinders as opposed to elastics or springs. The ri3d and several other places that said pneumatics don't work for shooting since they aren't fast enough were either placing the cylinders to far from the fulcrum or trying a punch, where the slower speed is a huge problem.
Unread 13-01-2014, 16:38
thursam's Avatar
thursam thursam is offline
AKA: Sam
FRC #3336 (Zimanators)
thursam is just really nicethursam is just really nicethursam is just really nicethursam is just really nicethursam is just really nice
Here's the intake system, as requested;
http://www.youtube.com/watch?v=2T0Mk...eature=mh_lolz
"If you want your children to be intelligent, read them fairy tales." - Albert Einstein
Unread 13-01-2014, 12:41
Hoffer5236's Avatar
Hoffer5236 Hoffer5236 is offline
Project Manager
AKA: Matthew Hoffer
FRC #5236 (Man O' War)
Hoffer5236 is on a distinguished road
We tried putting our cylinders on the opposite end of the fulcrum, but it made our length too significant to consider it being an option. Instead, we put the pistons (two 1.5in cylinders) on the same side as the basket with the ball. This decreased our length and seemed to give us some more power because pistons push with more force. The only problem that we ran into was that when the pistons were beginning to push up, the angle they were pushing at decreased any added force we had from leverage, giving us a much slower start.
This video shows our progression with the catapult.
http://youtu.be/r-9v9loC2As
Unread 13-01-2014, 02:06
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
May I direct you to the Robot in 3 Days? (Specifically Team BOOM DONE)
