Go to Post Dave, you're going to have quite the motor pool on Mars. :D - skimoose [more]
Unread 11-01-2014, 09:55
cnepo's Avatar
cnepo cnepo is offline
AKA: Charles
FRC #0868 (TechHOUNDS)
cnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to behold
TechHOUNDS Wheeled-Shooter Prototype 2014
Here's a video of our first Wheeled-Shooter Prototype for this year's game. This is the kind of work that gets accomplished when school's not in the way!
Specs:
- 8" FIRST Wheels (x4)
- CIM Motors (x2)
- Mini-CIM Motors (x2)
- PVC Guide Rails
Performance:
- 16 feet away from "Goal"
- Hits ~7'-8' into the "Goal"
Charles Nepomuceno
AndyMark Inc.
- Mechanical/Design Engineering Intern
FRC 868 TechHOUNDS (10 Years of FRC Involvement)
- Student: 2006-2010
- Mentor: 2011-Present
FRC 5010 Tiger Dyansty
- Mentor: 2014
https://www.facebook.com/FRC868
Unread 11-01-2014, 12:29
blaze8902 blaze8902 is offline
AKA: Buddy McWilliams
FRC #4265 (Secret City WildBots)
blaze8902 is on a distinguished road
Re: TechHOUNDS Wheeled-Shooter Prototype 2014
That looks pretty good. That top-spin will come in handy too.
This post from #1660
Motion of Projectile App
and this one from Ether
Parabola Equations
may come in handy during your prototyping.
One thing my team has been considering is the value/plausibility of allowing for two separate arcs, one for truss shooting and another for High Goal shooting. With truss shots, catching would be easier if you were to "lob" it (a more angular path) and for High Goal, a more "linear" path is probably better. So if you can shoot the ball two different ways, it might work out a little better.
Unread 11-01-2014, 12:34
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Very Nice! So I'm assuming you had a Cim and Minicim on each side? Were the 2 pairs of wheels the same speed or did you step up the second one?
Unread 11-01-2014, 12:51
cnepo's Avatar
AKA: Charles
Yup. We are using a CIM and Mini-CIM combination where the first set of wheels moves at a slower speed and the front set is a higher speed, following the same concept of a lot of shooters from last year's game.
Charles Nepomuceno
AndyMark Inc.
- Mentor: 2014
Unread 11-01-2014, 13:08
Could you post some close-up photos* of the ball after it's been through the wringer a few times? There's a lot of speculation about damage to the fabric.
* preferably with a camera that has a macro setting so the focus is sharp
Unread 11-01-2014, 13:43
16PolyBound 16PolyBound is offline
FRC #1388
16PolyBound is an unknown quantity at this point
What was the RPM of each set of wheels?
Unread 11-01-2014, 13:46
cnepo's Avatar
AKA: Charles
Here's a picture of our ball after close to 60 shots taken. The tears are from testing the compression on the ball, but nothing more than scuff marks once we got everything dialed in. We have continued to test and have not been able to create any more tears into the fabric.
http://i.imgur.com/5frvmdL.jpg
Charles Nepomuceno
AndyMark Inc.
- Mentor: 2014
Unread 11-01-2014, 15:59
The tears are from testing the compression on the ball...
Could you clarify what you mean by "testing the compression" ?
Unread 11-01-2014, 16:31
I'm also interested in the data from your compression testing. If you'd be willing to share it, I'm sure many people would appreciate it. Potential fabric damage tests would be great as well, as Ether asked.
Oh, and a comment about the wheels you're using: Have you considered using pneumatic tires? We saw many of them last year for Frisbee launchers, and I think they might work well for your case. Both the wheel and the ball will compress, and it should mesh well together, and the rubber tire material should work well with the ball fabric also. I think teams ran into some balancing issues, but they worked well in the end, generally. Cheng Shin 200x50s is what we prototyped with last year.
Unread 11-01-2014, 16:33
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
Are you guys using the newer (2012-present) kit wheels that have a "tread" on them, or the older ones that are smoother? Hard to tell from the vid.
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 11-01-2014, 16:59
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Considering that the post says that they're 8" wheels, I assume that they're the smooth ones.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 11-01-2014, 22:01
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
Nice to see the team making progress despite the school being closed. Go 'HOUNDS!
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 11-01-2014, 23:33
CheerlessBear's Avatar
CheerlessBear CheerlessBear is offline
AKA: Alexander
FRC #3082 (Chicken bot pie)
CheerlessBear is an unknown quantity at this point
If you where to use pneumatic wheels it might cause too much friction and tear the ball. Last year our robots pneumatic wheel in the shooter tore up frisbees so i would be concerned about using them this year.
Unread 11-01-2014, 23:45
OzzyArmas OzzyArmas is offline
OzzyArmas has a spectacular aura aboutOzzyArmas has a spectacular aura aboutOzzyArmas has a spectacular aura about
THANK YOU THANK YOU THANK YOU!!!!!
We are a rookie team, we don't have enough parts to prototype and I kept insisting a wheel shooter would work but doubt continued in the team because of all those catapults. But no one had tested the wheels until now so.... THANK YOU!!!!
Our Robot design is now definite :3
Unread 12-01-2014, 00:48
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
The challenge with a wheel shooter will be space, the OP's prototype is pretty much the size of the ball. If you wanted to be able to pick up, carry and chose when to fire you'd need to fit a separate pickup/carrying and firing space.
