Go to Post Can you believe we have 8 FRC teams in Arkansas this year??? Not quite Michigan, but... - Meredith Novak [more]
Unread 11-01-2014, 16:34
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
AndyMark AM14U Chassis Error?
Hey guys, this is my first post on Chief Delphi and I've got a question concerning the chassis included in the KOP, the AM14U. We got it on Thursday (we're from Chile, so we get things later ) and built it the same day. We also got the basic electronics mounted and programming on the cRIO, so we started driving straight away. We tested it and found out that the frontal wheels were slightly lifted up from the ground. So our CAD subteam sketched the chassis in Inventor based on the files from the AndyMark webpage and realized that the ToughBox shaft was 0.14" higher than the center of the outer wheels. Is this a design error, or is it intentionally designed in that way?
Unread 11-01-2014, 16:36
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: AndyMark AM14U Chassis Error?
Yes, it has a dropped center drivetrain to make turning easier.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
sebflippers sebflippers is offline
FRC #2914
sebflippers will become famous soon enoughsebflippers will become famous soon enough
It was intentionally designed that way to allow it to turn about a point. All six wheels on the ground would have caused lots of friction potentially stopping you from rotating.
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
It's intentionally designed that way, if there wasn't a "center drop," a six wheel drive with just rubber wheels wouldn't turn very well if any at all.
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Hey. Welcome to Chief. This design is intentional. The center wheel is dropped for turning; instead of attempting to go in a circle on a dime with 6 wheels, there are only 2 attempting to spin on a dime when you turn quickly. This is what's known as "West Coast Drive".
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
Your front and rear wheels should be slightly lifted from the center ones. this allows for turning with 6wd. It's awesome that you already have a driving chassis!! Great job!
My comments or views do not necessarily reflect those of any affiliated organizations or teams
Unread 11-01-2014, 16:37
I think it's designed that way. 6WD with a lowered center wheel is a very typical drivetrain--it gives better maneuverability than having 4WD with the wheels on the corners. Every Kitbot I can think of has had a dropped center wheel as an option.
If that doesn't suit you, you could remove the center wheel on each side; however, that may result in difficulty turning.
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Its intentional, it allows you to turn the robot easier. If all the wheels were at the same level, turning would be extremely difficult due to wheel scrub.
EDIT: Wow, 6 responses in the time it took me to type this. Welcome to CD. =P
Unread 11-01-2014, 16:42
Be sure to test on carpet. The friction is quite different, causing flat robots, especially long ones, to be unable to turn without tripping breakers.
Greg McKaskle
AKA: Lucas Alvarez
Thanks everyone for the quick answers!!! Our mechanical team was quite surprised, but now we know how these drives really work!
Unread 12-01-2014, 00:53
Oblarg Oblarg is offline
AKA: Eli Barnett
If you ever want a bit of entertainment, build a long 4WD base with traction wheels and try turning it, fully weighted, on carpet.
It's not a pretty sight.
"The breakfast of champions!"
Unread 12-01-2014, 01:00
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
In 2012 we ended up with 4WD base with 10in pneumatics and a gear ratio that was to high along with max weight, it wasn't pretty.
