Go to Post We asked the neighbors if we could block the road before we did it. We had the rack out for a couple of hours. They are getting used to us doing odd things during build season. - wendymom [more]
Unread 12-01-2014, 07:29
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: 3336 Catapult Prototype
Originally Posted by MichaelBick View Post
Based on how pneumatic works, they should push and pull at the same speed.
This may not actually be correct.
There is more pushing force in the pneumatic cylinder as there is more surface area on the piston being pushed by the air. There is less force when retracting (pulling) due to there being less surface area on the piston face. This is due to the shaft attached to the piston.
While this may not sound like much it can be significant depending on what you are trying to accomplish.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 12-01-2014, 08:39
FRC #1836 (MilkenKnights)
I didn't think about that, but you are correct. Regardless it is unlikely that Aroki's success is correlated with pulling instead of pushing but rather the angle and position that the pneumatic cylinders are pulling at.
Unread 12-01-2014, 17:39
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
However -- Pulling is going to gain a great deal of speed due to the volume needed to fill the cylinder is reduced. I understand you can gain the same speed pushing by introducing the exhaust from the solenoid back in with the input air -- have not tested it, but will tomorrow.
Unread 13-01-2014, 01:27
Or you can push with smaller cylinders
Unread 13-01-2014, 02:09
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
I worded my response earlier pretty poorly, I wasn't talking about the difference in speed/power between a cylinder going in or out. I was merely making a point about using a lever to account for the slower speed of pneumatic cylinders as opposed to elastics or springs. The ri3d and several other places that said pneumatics don't work for shooting since they aren't fast enough were either placing the cylinders to far from the fulcrum or trying a punch, where the slower speed is a huge problem.
Unread 13-01-2014, 16:38
thursam's Avatar
thursam thursam is offline
AKA: Sam
FRC #3336 (Zimanators)
thursam is just really nicethursam is just really nicethursam is just really nicethursam is just really nicethursam is just really nice
Here's the intake system, as requested;
http://www.youtube.com/watch?v=2T0Mk...eature=mh_lolz
"If you want your children to be intelligent, read them fairy tales." - Albert Einstein
