Go to Post If this doesn't show up in spotlight at some point I'm almost going to be sad. - Andrew Schreiber [more]
Unread 11-01-2014, 15:26
Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
cRIO won't reboot during imaging
Hello,
I have been trying to reimage our cRIOs with the v52 image. I have tried with an FRC and an FRC II. I have tried with and without a router. I have tried changing the console out dipswitch. Every time, it gets to the point where it waits for a reboot. I usually wait about 5 minutes, but I did wait for a half hour or more one time. I have already searched the forums for help. If anyone could give assistance or direct me to a helpful thread, it would be much appreciated.
Thanks,
Zaque
Zaque (Zach) H.
President
Programming/Electrical Lead
Unread 11-01-2014, 15:29
FF: Bobo Brigade
AKA: Zachary H.
Re: cRIO won't reboot during imaging
I also disabled the firewall and I have installed the 2014 NI FRC Update. I set my IP address to 10.33.52.6 and the subnet to 255.255.255.0. I have been using a standard Ethernet cord, not sure if I need to use a crossover.
Zaque (Zach) H.
President
Unread 12-01-2014, 12:06
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
I recommend following the guide at this link every time you re-image the cRIO, every time that I have sat down and followed it exactly I have successfully re-imaged it.
http://www.chiefdelphi.com/forums/sh...44&postcount=9
If you are unsure about needing a crossover cable, have the cRIO and computer connected via a switch or a router (wired connection).
Hope this helps!
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 12-01-2014, 12:29
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Hope this helps!
Link doesn't work, could you fix it?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 12-01-2014, 12:36
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Our team was having a problem similar to what you are describing. One thing that we noticed it that when you go to the command prompt and type "ipconfig" the LAN adapter connected to the robot had 2 IP address associated with it.
To change this and only have one IP address, go to your TCP/IPv4 Properties, and on the bottom select Advanced...
Delete the extra IP addresses.
When we did this it worked every time. It seems like the tool adds an IP address every time so if this also works for you, you may have to follow these steps every time.
Hope that helps
Unread 12-01-2014, 21:57
FRC #0539 (Titans)
Here the link works, fixed it above as well.
(evidently CD shortens the link with "..." so when you just copy the link from a different post, it copies the "..." link not the full one)
FRC Team 539
Unread 12-01-2014, 22:28
FF: Bobo Brigade
AKA: Zachary H.
I won't be able to try it until tomorrow, but isn't the subnet mask supposed to be 255.255.255.0?
Edit:I didn't try imaging with safe mode off, so hopefully that will fix the problem.
Zaque (Zach) H.
President
Unread 12-01-2014, 23:46
wt200999's Avatar
Texas Instruments
AKA: Will Toth
The subnet mask is actually not that important in this context (as long as the team number is the same across the board)
Unread 13-01-2014, 09:21
FRC #0539 (Titans)
I was imaging the 2014 Image on Saturday and believe the subnet mask was "255.255.255.0", looking back on the document I do not remember why i said "255.0.0.0" (I think an FRC guide said it someplace, not sure).
FRC Team 539
Unread 13-01-2014, 10:18
joecloud joecloud is offline
FRC #2805
joecloud is an unknown quantity at this point
I had the exact same problem the other day. The official guide says to wire the cRio to your PC directly. But what worked for me was connecting both to the d-link router.
Joe,
Programming: Team #2805
