Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 12-02-2003, 15:46
RAWdealer59 RAWdealer59 is offline
#0059 (RamTech)
RAWdealer59 is an unknown quantity at this point
Gyros!!
What unit of measurement does the gyro measure rotational velocity in? Any info would be appreciated. Thanks
Unread 12-02-2003, 16:46
Eugene Eugene is offline
#0321 (Lancers)
Eugene is on a distinguished road
Send a message via AIM to Eugene
Smile
The Gyro measures the angular velocity. Its range is +/-64deg/sec. That translates into 0.25 to 4.75VDC, which in turn gets translated into a BYTE. Therefore when the Gyro is still you get an output of 127. If it is going at 64deg/sec, it is 254, etc... As far as I’m aware of it the relationship between the rate of turn and the output is linear.
Some side notes:
64deg/sec is a pretty slow turning rate, because at maximum you can measure 1 revolution in 6 seconds. Also, many teams have suggested "filtering" the bumps in the output. You can do that mechanically (Put the gyro on a pad), electrically and electronically i.e. programming.
Good luck!
Eugene
Programming Gyros goegan31 Programming 33 19-05-2003 20:05
gyros archiver 2001 6 24-06-2002 02:35
Gyros archiver 2000 3 23-06-2002 22:58
Gyros (NOT the sandwich) archiver 1999 5 23-06-2002 21:53
