Gyros!!
What unit of measurement does the gyro measure rotational velocity in? Any info would be appreciated. Thanks
The Gyro measures the angular velocity. Its range is +/-64deg/sec. That translates into 0.25 to 4.75VDC, which in turn gets translated into a BYTE. Therefore when the Gyro is still you get an output of 127. If it is going at 64deg/sec, it is 254, etc... As far as I’m aware of it the relationship between the rate of turn and the output is linear.
Some side notes: 64deg/sec is a pretty slow turning rate, because at maximum you can measure 1 revolution in 6 seconds. Also, many teams have suggested "filtering" the bumps in the output. You can do that mechanically (Put the gyro on a pad), electrically and electronically i.e. programming. Good luck! Eugene |
| Programming Gyros | goegan31 | Programming | 33 | 19-05-2003 20:05 |
| gyros | archiver | 2001 | 6 | 24-06-2002 02:35 |
| Gyros | archiver | 2000 | 3 | 23-06-2002 22:58 |
| Gyros (NOT the sandwich) | archiver | 1999 | 5 | 23-06-2002 21:53 |
