Go to Post FIRST isn't about money or robots... it is about people. Take care of that and the rest will follow. - dtengineering [more]
Unread 11-01-2014, 17:01
Lyler1 Lyler1 is offline
FRC #4096
Lyler1 will become famous soon enough
Doubling up on Mecanum wheels?
Hi! this is my first post here!
I have a question regarding Mecanum drives. My team, 4096, built a mecanum drive last season, all in all good, but we felt that the torque on our wheels was being wasted because our wheels were slipping. This year, we want more traction on our wheels in order to achieve better acceleration. How feasible would it be to put 2 mecanum wheels side by side next on each corner. They would be fixed on the same drive shaft, so they would rotate in unison, almost like an extra wide wheel. At the moment, 6 inch VEX mecanum wheels are our top candidate.
Any advice is appreciated! Thanks!
Unread 11-01-2014, 17:17
Re: Doubling up on Mecanum wheels?
I've never seen that on an FRC robot, but I have seen blocks of multiple mecanums working together.
However, I suspect that you won't see improved traction. Mecanum rollers don't really get down to microscale interactions like treaded wheels, so I suspect that while a doubled traction wheel will show an increase in traction due to "interesting" stuff happening where we can't see, a doubled mecanum probably won't.
If I might make a suggestion, search for "octocanum" here on Chief Delphi, and see if you think it will work. Octocanum pairs each mecanum wheel with a traction wheel and switches wheels depending on whether traction or maneuverability is desired.
Unread 11-01-2014, 17:19
FRC #4096
8 wheel mecanum drive
Is it feasible to make a mecanum drive with two side by side wheels on each corner to add traction?
Unread 11-01-2014, 17:24
Re: 8 wheel mecanum drive
Doubling mec wheels will likely not add traction.
Unread 11-01-2014, 18:28
Jared Russell's Avatar
Taking a year (mostly) off
I don't know about adding traction, but it sure does look cool.
Unread 12-01-2014, 13:16
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Doubling your wheels will double the surface area in contact with the floor. This reduces the force on each wheel, reducing each wheel's traction. In short, you'll see no significant improvement in traction by increasing the number of wheels you have.
Couple that with the fact that mecanum wheels must slip in order to work, and you're better off sticking with 1 mecanum wheel in each corner.
Unread 12-01-2014, 14:20
thenomnivore's Avatar
thenomnivore thenomnivore is offline
AKA: Ramirez
FRC #1212 (The Sentinels)
thenomnivore is an unknown quantity at this point
Just as a general rule of thumb, mecanum drives are crap when it comes to being able to grip and just exceeds in slipping on surfaces. Honestly, the only advantage mecanums have to other drive trains is the strafing ability and mobility but is bad when it comes to speed and being able to push other robots. Other drive trains that are available are direct drive or the 6 wheel drop. But its up to you on what to use.
A sandwich only gets tastier when defeated.
Unread 12-01-2014, 14:24
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Originally Posted by thenomnivore View Post
but is bad when it comes to speed.
I'm afraid I don't follow your logic here. Speed of a drivetrain is more dependent on motors and gear boxes than anything else. As far as I'm aware the wheels shouldn't have too big of an impact (except for size of the wheels, but a traction wheel of the same size won't be any different than a Mecanum wheel). You are correct in that pushing ability is greatly reduced by having mecanums, but speed is not.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 12-01-2014, 14:40
AKA: Ramirez
Sorry i forgot to correct myself on that part.
Unread 12-01-2014, 15:23
Whenever someone says that, I always wonder what they mean.
Unread 12-01-2014, 15:39
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
I can't see double mecanums adding traction or speed, but I can defiantly see them adding weight!
Unread 12-01-2014, 16:24
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
24 looks even cooler!
http://youtu.be/2O8Cj0XiRIM?t=3m47s
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 12-01-2014, 17:07
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
And it has a minibot!
Unread 12-01-2014, 17:15
Robotics Engineer
Technically, the rollers on the mecanum wheels don't slip in an ideal design (there is no slip between the surface of the rollers and the carpet). Often, however, there isn't a 1-to-1 relation between the tangential speed of the wheel and forward velocity of the robot.
So, if you look at it from the perspective of the wheel, and you don't want to take the above paragraph (or more) to describe it, you say that the wheels are slipping.
It may not be technically correct, but I've come to use it as mecanum "slang" if you will. Unfortunately, I use it so much that I didn't think twice before using it here.
