Go to Post It's a FIRST thing. You gots to understand. - Koko Ed [more]
Unread 12-01-2014, 19:26
Joshua Sicz Joshua Sicz is offline
FRC #2403
Joshua Sicz is an unknown quantity at this point
Is it possible to shoot the ball with pneumatics?
My team has done some prototyping with some pneumatics to shoot the ball. We used a lever arm but it seem to never get as high as we would like so we have been trying to play with one v. two cylinders. Then I came up with the best way to wire the pneumatics to get the best performance. I haven't yet tested it out but I need help to see if it is even possible. I have attached a diagram for the system. One is the diagram for how its set up and the other is for the shooter. The red is the cylinders. Thanks!
ID:	15820  Click image for larger version
Unread 12-01-2014, 19:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Is it possible to shoot the ball with pneumatics?
It appears to be possible.
http://www.youtube.com/watch?v=QRmHqCGYnwI
Unread 12-01-2014, 19:33
Originally Posted by MrForbes View Post
Or this:
http://www.youtube.com/watch?v=YDuA0...ature=youtu.be
Unread 12-01-2014, 20:10
Oblarg Oblarg is offline
AKA: Eli Barnett
That's a pretty impressive one. I wonder how they managed to get that much oomph out of a single cylinder (which looks like a rather small one, at that).
449 got our first-iteration prototype pneumatic shooter working (i.e. shooting through the goal from the ground) today, three days after deciding to try one. Not quite that slick, but very functional. It's not all that difficult; the geometry of the piston mount is the trick, look closely at some of the catapult designs teams have posted to get an idea of how to set one up.
You don't need any tricks with multiple solenoids or whatever to maximize airflow, by the way - we were getting the ball to the required height with a single solenoid feeding three cylinders.
"The breakfast of champions!"
Unread 12-01-2014, 20:17
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
Yes, it's possible. Our prototype did it today and scored the high goal. It's lousy but would only need to be about twice as good for the actual competition.
We used a pretty big cylinder operating on a lever arm. This principal worked for us ok also in 2008.
Unread 12-01-2014, 20:19
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
What kind of distance are you getting on the shots? Right under the goal, or full court truss pass?
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 12-01-2014, 20:23
AKA: Eli Barnett
Not full-court truss pass, but we can score from a solid 5-10 feet away if we put it on the right trajectory. Our strategy doesn't involve a super-powered shooter, though.
Unread 12-01-2014, 20:46
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
It is very possible! Makes for some great footage too.
842, 1212, and possibly 2403? I predict lots of pneumatic catapults at AZ this year.
Unread 12-01-2014, 21:07
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
We're prototyping one too. We're hoping to get it running tomorrow.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 12-01-2014, 21:09
Trey178's Avatar
Trey178 Trey178 is offline
M.C. in Training
AKA: Trevor
FRC #0178 (2nd Law Enforcers)
Trey178 is an unknown quantity at this point
We've come up with a 3-stage piston assembly. It has the power to reach the high goal but questions have arisen about how to seat the ball for a optimal shot. This could answer both this and how to mount the mechanism. Thanks for the links
Unread 12-01-2014, 21:13
DonRotolo's Avatar
Back to humble
FRC #0832
Just be careful to comply with R89 A
Your pressure vent plug MUST be able to vent ALL stored air pressure. If the solenoid valve is closed and the vent plug is open, the pressure is not released. This will fail inspection.
Unread 12-01-2014, 21:20
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Go Pneumatic Catapults! Its working great for us!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 12-01-2014, 21:22
yash101 yash101 is offline
AKA: null
Prepressurize the piston, but have the stroke locked by a latch. That way, there will be a ton of energy built up, capable of extending the piston in very little time. We, team 1165, have also prototyped a pneumatic shooter, that basically catapults or flings the ball effectively.
When designing this system, make sure your latch is very well-made because there will be a ton of pressure in it, especially at 60PSI working pressure!
Also, beware of hands because this suddenly flings with a ton of force, which has the capability to de-hand you (if that is a word).
I'll try to inquire and post a video of this shooter as soon as we finish the changes to it!
Unread 12-01-2014, 21:29
AKA: Ledge
will this release all the air in the system? http://www.chiefdelphi.com/forums/at...0&d=1389572570
I think it does, I will double check in the morning.....
Unread 12-01-2014, 21:32
AKA: Ledge
You may not want to go with a locking system, see Don Rotollo's post...
There is another way, you do not need to use locking method, see diagram on the first post on this at top of page
