Go to Post I have never before seen the words "smaller" and "Saturn V" used in the same sentence. Wow. :yikes: - DonRotolo [more]
Unread 12-01-2014, 21:30
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
How to figure out belt lengths?
I know WCproducts has a calculator but I am getting really confused with it. How do I figure out the size belt I need? We are using 36 tooth pulleys and from center point to center point the distance is 9.843 inches.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 12-01-2014, 21:37
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: How to figure out belt lengths?
Well, plug in your numbers for pulley size and desired wheel spacing, and the calculator gives you the possible belt lengths. You are unlikely to get exactly what you desire for a spacing, but you'll have two options that are close.
In your case, your options are to use a 130 tooth belt at a spacing of 9.2529 or a 140 tooth belt at a spacing of 10.2372.
When you lay that out, you need to be fairly accurate, so I'd strongly recommend calipers, layout die, and a machinist's scale.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 12-01-2014, 21:44
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
To calculate the belt length you would add both circumferences of the pulleys together then divide by 2. You would then add this to twice the distance between the centers. Basically you have this equation:
((C1+C2)/2)+(2*d)
Once you have this length, divide it by the length of one of the teeth. This gives you how many teeth you need on the belt. If its a decimal, just round up.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 12-01-2014, 21:46
yash101 yash101 is offline
AKA: null
You can try the datasheet, or you could try some basic arithmetic.
If it is on two sprockets:
PHP Code:
Here it is:
sprocket
+belt
as per that ascii art, basically find:
the circumference of ONE sprocket (because you have 2)
Add that to the distance between the center points of the sprockets, times 2.
subtotal those and you should be off in flames!
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
((C1+C2)/2)+(2*d)
To make it even more clear:
You would want to use the pitch diameter here.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 12-01-2014, 21:47
FRC #6357
((C1+C2)/2)+(2*d)
I'm not speaking to the correctness of this formula, but if you are going to use a manual calculation, make sure you use the pitch diameter of the pulley. Also, you'll need to round up by 10 for the HTD timing belt. Other belts may have other size selections. But it's not like every tooth count is available.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 12-01-2014, 21:54
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
If you are using our Belt Calc, the calculator will run any time a value changes or when you press enter. Entry boxes that are white are user edited material. Greyed out boxes are what the calculator returns. The calculator runs in default 5mm HTD pitch.
To use, first select the two pulley sizes. The dropdown features all VEXpro pulley sizes, and by selecting other, you can manually enter your own size. In your case, you would need to enter 36 for each pulley, which is a standard VEXpro pulley.
Next, enter your desired center distance. In your case this would be 9.843". The calculator will try to find the nearest VEXpro belt sizes above and below this number.
Next, you can choose to edit the center distance tolerance with the Center Add box. This manually adds distance to the center distance to adjust belt tightness. The default +.001 works well in most cases. YMMV
The calculator then outputs numbers for the two nearest belt sizes, Smaller and Larger, than the desired center distance.
# of Teeth is the number of the teeth in the belt.
Center Distance is the exact center distance for the pulley+belt combo, plus the center tolerance.
P1 Teeth in Mesh is the number of teeth on Pulley 1 that are in the belt mesh. This number is useful when you have a very large and very small pulley on the same belt. Too few teeth in the mesh can result in belt slippage. For your case, this number can be usually be ignored.
P2 Teeth is the same thing as above but for the second pulley.
The calc says that you could use either a 130 or 140 tooth belt, which would have a center distance of 9.2529 or 10.2372 respectively.
Let me know if you have any more questions
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 12-01-2014, 21:56
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
http://www.gates.com/first/resources.html
I would use this design tool from Gates.
If you put in your data, it says you need a 136 tooth (680 mm) belt and that will give you your desired center distance.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 12-01-2014, 22:01
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Thank you, all of you. This really helps!
Unread 12-01-2014, 22:06
magnets's Avatar
magnets magnets is offline
basically find:
Make sure you use the pitch diameter to find the circumference, and don't multiply the whole thing by 2. If you're using the same size pulleys, then its
C+2d.
It's not 2(c+d)
