Go to Post You know you are addicted to FIRST when you have trouble describing it because you realize it truly is way more than just a robotics competetion. - vivek16 [more]
Unread 08-01-2014, 18:32
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
Team Role: Electrical
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
Which batteries to use?
This year we are allowed to use one of six different batteries per R31?. Does anyone have an advice on which to use and which not to use? Any experiences with any of these batteries?
R31:
"The only legal source of electrical energy for the ROBOT during the competition, the ROBOT battery, is one of the following approved 12VDC non-spillable lead acid batteries:
Enersys (P/N: NP18-12)
MK Battery (P/N: ES17-12)
Battery Mart (P/N: SLA-12V18)
Sigma (P/N: SP12-18)
Universal Battery (P/N: UB12180)
Power Patrol (P/N: SLA1116)"
Thank you,
Brycen Wershing
1678- Citrus Circuits
Unread 08-01-2014, 19:23
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Which batteries to use?
All of the listed batteries are essentially identical (in form, function, and specification). FIRST does that on purpose, for both safety and team parity. You probably got an Enersys battery in your Kit of Parts (two, if you're a rookie team). You can buy any of the listed batteries as spares, and they will be interchangeable.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 08-01-2014, 22:14
DonRotolo's Avatar
Back to humble
FRC #0832
Here's a thought: Buy one or 2 of each, test them*, and report back to us. We'd like to know too...
*If you need help designing those tests, just ask.
Unread 11-01-2014, 11:14
Ryan Barnhart Ryan Barnhart is offline
Can do things
FRC #0503 (Frog Force)
Ryan Barnhart is on a distinguished road
The batteries from Andymark are good, aside from the fact that they are 17.2Ah. Our team uses the same MK ES17-12, but with 18-20Ah. This is only because they last longer.
Unread 11-01-2014, 11:39
Some of the specs are noticeably different. That may be real or it may just be differences in the way the two manufacturers test or rate them.
Unread 12-01-2014, 20:38
These different types are available from different sources if you were to order an NP18-12. These are the functional equivalent batteries to the NP18-12 to make it easier for teams to obtain additional batteries locally.
Unread 12-01-2014, 21:28
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
I think this is a welcome change that allows you to obtain your batteries locally in many cases.
If you walk into a local battery seller, and ask for a MK Battery ES17-12, they will probably look it up and come back with some other brand anyway. Any differences between these are so slight as to be imperceptible, although I'm sure there will be many discussions on here with anecdotal evidence that certain brands are better or worse than others.
Universal Battery and Power Patrol are widely available brands. Battery Mart, I believe, is a house brand for a wholesale outlet.
Andy Mark is already out of batteries for the season, so this will help many teams. Shipping on these batteries is expensive, too, so anything that helps teams obtain them locally is of help.
I'm surprised they missed several other manufacturers that make equivalent batteries.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 12-01-2014, 21:35
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Where are you seeing this?
This shows otherwise.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
I don't think they did miss them. From the R31 blue box: "To seek approval for an equivalent battery, please contact frcparts[at]usfirst.org with the battery supplier and part number. Approved batteries will be added to the list above." (Slight change so the contact doesn't get spammed to death.)
Unread 12-01-2014, 21:37
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
But fortunately they've provided a system to suggest additions by emailing frcparts@usfirst.org
Edit: Whoops, Eric beat me to it.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 12-01-2014, 21:49
AKA: Gerry
Andy Mark is already out of batteries for the season, ...
Only the FirstChoice is sold out. As Ankit said (with a link), you can still buy the batteries from AndyMark.
Cal
Fairport, NY, USA
