Go to Post Keep your chin up, your safety glasses on, and don't let the magic smoke out of the electrical components and you'll do just fine :) - rsegrest [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 12-01-2014, 22:36
Lemon's Avatar
Lemon Lemon is offline
Builder of Robots
AKA: Andrey (Gooby)
FRC #2383 (Ninjineers)
Team Role: Electrical
Lemon is an unknown quantity at this point
Rotary Sensors and Swerve Drive
This year we have decided to go with swerve drive to operate our robot. Knowing that optical encoders read zero regardless of position on start up, Ive begun to consider using potentiometers to keep track of steering position. My only concern being that the limited number of turns could possibly prove problematic. So I guess my question is more along the lines of this, would potentiometers or optical encoders be more suitable for such a drive system? And for teams that have used swerve drive and potentiometers, have you ever found them to be restrictive in terms of how one must drive in order to make sure you dont max them out? Or do you use continuous potentiometers?
Unread 12-01-2014, 22:38
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Re: Rotary Sensors and Swerve Drive
We found absolute encoders to work well with appropriate programming.
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
Unread 12-01-2014, 22:42
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Continuous potentiometers seem to be what you're looking for. If your swerve drive can turn fast enough, another option is to program it to unwind itself after a certain number of turns.
Unread 12-01-2014, 23:05
Lemon's Avatar
Builder of Robots
AKA: Andrey (Gooby)
Okay then question, what absolute encoders, or continuous potentiometers do you use?
Unread 12-01-2014, 23:16
Andrew Lobos Andrew Lobos is offline
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
In our FTC swerve drive, we found that the deadband point at the rollover in continuous pots were too large for the sensors to be used effectively. I'm not sure if this becomes less of an issue at FRC scale, but it is something to be mindful of.
I know several teams have used absolute encoders, like USDigital's MA3 (http://www.usdigital.com/products/en...tary/shaft/MA3) successfully, but I have no experience with them.
Unread 12-01-2014, 23:21
mwmac's Avatar
JWBWIFWWWADD
AKA: Mike MacLean
usdigital MA3-A10-250-N
Unread 13-01-2014, 00:02
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
There's a great magnetic encoder made by Austria Microsystems with a whole lot of operating modes. You can find the WPI reference right here: Encoder .
Extra tip: If you decide to go with this one, and wanted to use the PWM signal, just use a low-pass filter to convert to good ol' analog signals for you cRIO module.
Good luck!
Unread 13-01-2014, 07:54
You can obtain 5 turn or ten turn pots for this application. You also can use reduction drive (gear or belt) to connect to a standard pot or encoder that only has 270 degree rotation.
Unread 13-01-2014, 08:18
Gdeaver Gdeaver is offline
FRC #1640
We use http://www.digikey.com/product-detai...393-ND/2620662
Have used them for 2 years on the swerve and have worked well.
Unread 13-01-2014, 16:16
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
You can also use an incremental encoder with an index to detect a fixed zero position. However, the last I knew, these did not work well when using the built-in position control of the Jaguars, if you try to use the index pin on the Jaguar's encoder input. You'll have to have a procedure for making sure the index is picked up before you can rely on this reference. For instance, it might be possible to have the students who set the robot on the field manually twist each swerve unit so it passes the index, after the robot is powered up but before it is enabled (obviously). Another option is to have the swerve units rotate for a time right after things are enabled, in order to ensure the index has been 'seen'.
Let us know if you find a absolute optical encoder that isn't expensive, the magnetic ones seem to be more manageable in this way.
Unread 13-01-2014, 19:23
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
I use the US Digital MA3 for all of my swerve builds.
They are single turn, but limitless. Their behavior near the 0 point is reasonable.
We count turns as we go and it works well.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 21-01-2014, 16:50
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
My first year on a team I had the same problem as the OP. Our solution was to use the Cherry AN8 sensor. This sensor is a Hall Effect rotational position sensor. It somes in a 360 degree variant, and is analog output. It will output a voltage between 0.5V and 4.5V, so it is easily connected to the analog breakout board. I never had any problems with a dead band on the sensor between the 0 and 360 area.
The reason we love this sensor is that it is absolute between power cycles of the robot, it will always output based upon the magnet's orientation. It will also automatically wrap the voltage at the 0-360 transition, so there is only one voltage per angle (as opposed to the multi-turn potentiometers).
Mechanically it can be mounted similar to the potentiometers, there is a magnetic head which has to be tied in to the rotational system. Then the sensor body gets mounted a few millimeters above that sensor head (it is a non-contact sensing system).
Here is the datasheet for the sensor:
http://www.cherrycorp.com/english/se...AN8_Series.pdf
Here is a link to the Digikey product page for the sensor:
http://www.digikey.com/product-searc...words=CH187-ND
I also had created a C++ class for this sensor, so if anybody is interested let me know and I can dig that out and post it.
- Ian McInerney
Alumni & Mentor, Team 2022 Titan Robotics
Junior, Iowa State University majoring in Electrical Engineering
Unread 21-01-2014, 17:05
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
We're using a quadrature optical encoder with a homing tick from USD.
We used them in the recent past with great success. They were very accurate and reliable, in part because of the sealed body. They were a little on the expensive side but we got a special deal from USD. I'll try to get back with model No.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 21-01-2014, 21:43
We have used pots simply because we wanted to know if we had turned more than 360 degrees and in which direction.
