Go to Post In the now immortal words of will.i.am, "This stuff is really good!" - neshera [more]
Unread 13-01-2014, 00:29
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Team 314 Launcher
This is our final design review launcher, there is still evaluations being done but this video does a good job of showing our half court-in sweet spot. Hope you enjoy!!
https://www.youtube.com/watch?v=lWRYRpHFIaE
Here is the link for Intake and Shooter video, roughly 19 feet away.
https://www.youtube.com/watch?v=I1coTKRfynA
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 13-01-2014, 01:24
Re: Team 314 Launcher
How do you plan to pull back, hold, and release it ??
Unread 13-01-2014, 01:32
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
We have a gen 1 shifter that I took the high gear out of and milled the teeth (3 of them)down to a flat face so that when the high gear transfers from low (winching the catapult back) to high (releasing into a free spin) where the dog has nothing to grab and the shaft releases to the direction of tension making the ball fly. On the output shaft there is an external ratcheting mechanism so that the tensions is released from the motors as it is drawn back. Also, we adjust our hard stop so we can get different angle shots such as a blop shot for a good truss toss.
Unread 13-01-2014, 02:15
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
What are you using as a spring? Do you find the initial angle of the spring makes a difference?
Unread 13-01-2014, 04:43
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Great prototype, how far were you guys from the goal in those first couple of shots? Looked like half field.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 13-01-2014, 05:11
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Impressive!
Are you guys changing any of your parameters between the different shot ranges?
It looks like it really is a "sweet spot" where everything stays the same: retract length, hardstop length, tension, etc.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 13-01-2014, 08:51
Physicguy's Avatar
Physicguy Physicguy is offline
It exploded on its own I swear...
AKA: Jeffin James
FRC #2582 (Pantherbots)
Physicguy is just really nicePhysicguy is just really nicePhysicguy is just really nicePhysicguy is just really nice
What was your effective range on that launcher? It seemed like you could still score really close to the goal.
Unread 13-01-2014, 09:13
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
This is a really impressive catapult. Basically what we are looking for as well. Good job!
Mentor 2415
Unread 13-01-2014, 14:04
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
It starts off at half field, directly under the truss. We then move it forward. We can score in a 21 ft radius from the from of the goal with the same hard stop point and spring tension and release point. We are only going to change hard stop for the purpose of a "soft shot" for good truss catchable pass.
Unread 13-01-2014, 14:05
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
We can be as close as 3 feet away with the same sweet spot as half court
Unread 13-01-2014, 14:06
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Originally Posted by Mr. Lim View Post
Impressive!
Exact same tension and release point. Our hard stop doubles as hard stop and release point adjuster.
Unread 13-01-2014, 18:22
Colin Small Colin Small is offline
FRC #0114 (Eagle Strike)
Team Role: CAD
Colin Small is an unknown quantity at this point
I'm not quite sure what what you mean. Is it that you have it timed so that the gear isn't engaged (because of the three shaved teeth) when you want to poll the dog out? I'm confused....
Unread 13-01-2014, 18:36
WaterClaw's Avatar
WaterClaw WaterClaw is offline
Comandante
AKA: Andrew A. Matthews
FRC #2512 (Duluth East Daredevils)
Team Role: Tactician
WaterClaw is on a distinguished road
Too inaccurate for my full appreciation.
Insanity is correlative only to the standards of a culture. Cultures are often defined by their technology. Technology only advances by the efforts of those who would be considered insane. So thank your local FIRST team for advancing society.
Unread 13-01-2014, 21:22
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Very impressive catapult. I look forward to seeing what you guys have together in robot form in just a few weeks.
Unread 13-01-2014, 22:17
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
I do not know if this is sarcastic or not but 98% accuracy from anywhere inside the truss to goal area is pretty good in my book for a PROTOTYPE...The one miss was from not pulling back to the same spot attempting to see if less tension on the same dead stop point would give us more of a line drive rather then a tad bit of loft. And clearly shown, the less tension was not enough to make a half court shot...it was very valuable data for our team and proto testing. Again, this is not attacking just clarifying just in case it was not sarcastic. Thanks.
