Go to Post Goodness gracious professionalism - Billfred [more]
Unread 11-01-2014, 05:02
Yerdan Yerdan is offline
FRC #3646
Yerdan is an unknown quantity at this point
Concerns about goalie zone
Eventough I read the manual for several times,I couldn't be sure about something. Does the every part of the robot have to be in goalie zone to make defense by increasing its height or if some of the robot's frame is on the goalie zone's carpet is that enough?
Unread 11-01-2014, 05:21
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: Concerns about goalie zone
Rule G23 says:
If a ROBOT is in contact with carpet in its GOALIE ZONE, and for only one ROBOT per ALLIANCE at a time, there is no height restriction; however, any extension or combination of extensions above 5 ft. may not extend beyond a vertical cylinder with a 6 in. diameter (see examples in Figure 3-5).
Thus it seems to me that, if any part of the robot is in the zone (by touching it), it should be able to extend upwards.
Does anyone else remember when TBA signatures actually worked?
Unread 11-01-2014, 10:56
jdh042397's Avatar
jdh042397 jdh042397 is offline
Being a nerd really pays off!!
FRC #4063 (TRikzR4kiDz)
Team Role: Electrical
jdh042397 is an unknown quantity at this point
Originally Posted by bduddy View Post
Rule G23 says:
Youre absolutely right. You only have to be in contact with it. If you wanted to just touch a corner of the zone and block youre more than welcome to.
2014 Hub City Regional Engineering Inspiration
2012,2013,2014 Alamo Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
2013, 2014 Hub City Regional Finalist
"Robotics are beginning to cross that line from absolutely primitive motion to motion that resembles animal or human behavior."
J. J. Abrams
Unread 11-01-2014, 11:52
GaryVoshol's Avatar
Cogito ergo arbitro
However G4 says for the start of the match
C. entirely within their GOALIE ZONE, or
So if you're planning on starting there, you have to completely fit.
Once the match starts, you only have to be in contact with the carpet inside the GOALIE ZONE.
(since 2004)
Unread 11-01-2014, 12:44
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
Smile Re: Concerns about goalie zone
thank you all so much my whole team keeps asking me that question.
Unread 13-01-2014, 02:31
FRC #3646
Thank you guys , that was really helpful
